Booster
Cast Iron
- Mar 18, 2005
- Springfield, OR
Helo, Let me first say i have bought a lincoln arc welder about 3 years ago and just started welding and learning by doing. I've read up on welding to some degree also.
I have a couple of particular geometries i am welding together and i have become so frustrated with myself that i cannot get a good weld.
My camera is broken so i cannot yet get a photo of this so allow me to form a picture for you.
All is mild steel and about 12 gauge.
I have a small cylinder i am welding to a large cylinder. Imagine a 12" dia can sitting upright. Made from 12 ga rolled into a tube. I am welding to it another cylinder shape, and it is also oriented upright. It is 4" long 3/4" dia and also about 12 ga thickness. Where the two objects meet, i am trying to form a beed on both sides.
I was told to weld these when upright and use about 30 deg up. Also using 6013 rod 3/32" size. It seems that when the rod melts down into it, it is so unpredictable and sort of pulls into various directions. It globs and forms gaps. I recently tried laying a piece of welding rod against where the to curved edges come together in hopes that this would aid in filling it in.
I have a garbage wire feed welder from harbor frieght that i never use and i realize that wire is probably gonna be easier, but i would prefer to master the arc welding on this first.
Any tips on this?
If i left out some details, let me know. I think i covered it and hopefully you can understand the parts i am welding together.
Any tips on this?
