shear gap adjustment - Page 3
Page 3 of 3 FirstFirst 123
Results 41 to 47 of 47
  1. #41
    Mar 2005
    Kansas
    8,327
    550
    4094
    Shears are different than punch/die. The two pieces are free to move away from each other.
  2. #42
    Jan 2005
    The Netherlands
    6,451
    336
    1836
    Quote Originally Posted by gbent View Post
    Not when it matters That is while cutting Then the 2 pieces are still one piece (Does that makes sence)But anyhow the gap setting is still the same percentage
    One can check the cutting edge 1/3 cutting (Smooth surface)2/3 breaking (rougher surface)
    Peter
  3. Likes swarfless liked this post
  4. #43
    Apr 2006
    Manchester, England
    9,083
    1480
    6028
    Quote Originally Posted by drylakemachine View Post
    replaced many a shear blade . We always set them to cut paper/
    Me too. Wet paper if you want to be really picky.
    Regards Tyrone.
  5. #44
    Jan 2005
    The Netherlands
    6,451
    336
    1836
    Quote Originally Posted by Tyrone Shoelaces View Post
    Regards Tyrone.
    Papershear then
    Peter
  6. #45
    Apr 2006
    Manchester, England
    9,083
    1480
    6028
    Quote Originally Posted by Peter from Holland View Post
    Papershear then
    Peter
    8ft by 3/16" sheet metal. Of course you wind it down by hand a few times before you give it the green light.
    Regards Tyrone.
  7. #46
    Jan 2005
    The Netherlands
    6,451
    336
    1836
    That shear has a lott to endure then
    Peter
  8. Likes dkmc liked this post
  9. #47
    Jan 2002
    Upstate NY -In the Flats next to the corn fields
    9,360
    1675
    2668
    Every shear maintenance manual I've ever read, and any sheet metal or fabricating book I've ever seen specifies .xxx thousandths of an inch of clearance for a given thickness of material when adjusting shear blades. Cutting any thickness metal with the blades set close enough to cut paper seems like either a lack of proper procedure, or proper knowledge of the machine. In any case, yes, hard on the machine for sure.
  10. Likes Peter from Holland liked this post
