shear tonnage for 1/4" aluminum?
Results 1 to 6 of 6
    Nov 2007
    ohio
    632
    32
    17
    Smile shear tonnage for 1/4" aluminum?
    I spent 30 minutes on google and couldn't find the answer.
    If I am planning on shearing 48" wide plates of 1/4" 6061 aluminum, what tonnage shear should I be shopping for?
    Thanks in advance if you can answer or point me in the direction of an on-line resource that will work. (found one but it didn't work)
    Chris
    Mar 2004
    Edison Washington USA
    10,574
    1030
    5612
    Its rare to see shears rated by tonnage- usually they have a thickness rating.
    this roper whitney chart says 6.25 tons per inch, meaning about 300 tons for 48", in 1/4" mild steel.
    Tonnage Chart for Roper Whitney Equipment
    most shear manufacturers, tend to rate aluminum about the same as mild steel, in terms of shear capacity, especially since hardness and temper can vary within an alloy.
    So even though, in some cases, you can push the shear to cut thicker aluminum than steel, its generally rated the same.
    Mar 2005
    Kansas
    7,912
    489
    3763
    To temper Ries' reply, a suitable shear won't develop that much tonnage, because the blade will have shear. (puns intended) A shear will not cut the entire 48" at one time. The blade starts on one edge and progresses across the sheet. I will also agree with Ries, just look for a 1/4" capacity shear.
  4. Likes Ries liked this post
    Mar 2004
    10,574
    1030
    5612
    Thats why they dont rate shears by tonnage- because the tonnage being used is literally moving across the width of the material as you cut. Those charts are usually for figuring tonnage for the shearing action of complicated shapes of punches.
    300 tons is the amount you would need if you were shearing the whole piece straight down at once, press brake style.
    Nov 2007
    ohio
    632
    32
    17
    Thanks for the input. Obviously I am new to this, but I have a project exclusively cutting 1/4" aluminum in squares/rectangles.
    I've had good luck buying at HGR and wanted to be sure if I bought something, it would do the job. I don't want to rely on them to say it will work.
    I will check inventory then Google specs of the model.
    Regards,
    Chris
    Michigan
    110
    65
    I have a Pexto 10ft shear rated for 10ga steel the full width and will handle 1/4" aluminum 48" wide. Just for reference. It's a mechanical shear.
    Pretty much any hydraulic shear good for 1/8" steel or better should be able to handle 1/4" aluminum.
    A shear with adjustable knives helps too, as the gap for 20ga is different than 1/4".
