Sheet metal heat warping
Likes Likes:  0
Results 1 to 12 of 12
    Aug 2014
    Hoboken NJ
    88
    15
    Default Sheet metal heat warping
    Top of the day people, Got a major problem and I need help. Got twenty of these boxes we did. The corners are soldered. From us spot welding the bands around the boxes we managed warp the sheet metal (See pictures). I’m hoping that one of you has a solution that was handed down to you long ago. The boxes are made of everyday carbon steel .030 sheet. All of you have a great holiday, Bob, Bean and Baby hound dog
    Attached Thumbnails Attached Thumbnails dsc06877.jpg   dsc06876.jpg   dsc06875.jpg
    Mar 2011
    Geneva Illinois USA
    6,347
    2750
    2469
    When did the warpage occur?
    Tom
    Aug 2012
    California, Central Coast
    4,091
    2234
    1605
    A bead or lip would help a lot, have you done these before?
    Aug 2014
    Hoboken NJ
    88
    15
    The warpage was done from the heat of the spot welder. These are replicas. There was no bead or there can be none.
    Oct 2005
    dexter mich
    284
    12
    69
    And you have tried to straighten?
    Aug 2012
    4,091
    2234
    1605
    The welds shrink when they cool, the surrounding metal can not so it distorts. It looks like the big stud and the heavy bracket opposite the stud are the problem not the spot welded strip. Better pics?
    Mar 2006
    Vershire, Vermont
    2,124
    1405
    673
    Stretch the shrunken areas. Some easy, some not so.
    Spot welds easy to stretch slightly. Could straighten the edges by shrinking them slightly, too.
    Aug 2010
    Santa Cruz, CA USA
    172
    268
    64
    Plus one on the shrinking idea from neilho, shrinking the sides should be able to bring it in close. Close enough is an open question.
    Sep 2010
    Vancouver Canada
    957
    713
    353
    I'm amazed that warpage happened from regular spot welding. We've done lots of spot welding on 20Ga (.036") and even 22 and 24Ga and not seen that. It looks from the pictures more like the boxes got mechanically squashed while welding perhaps. It looks like the open end of the box has been squashed in from the two sides with spot welding, warping the other two sides.
    Aug 2012
    4,091
    2234
    1605
    Quote Originally Posted by Rob F. View Post
    Quote Originally Posted by rcoope View Post
    Pretty sure the spot welds are not the problem here, go back and look at the pics to see what is welded on the two sides that actually did warp.
  11. #11
    Dec 2016
    Arizona
    211
    84
    105
    It does appear to me also that the heavy bracket and stud are where the warpage is occurring. It will be hard to join those two heavy components in the middle of that sheet without any warpage. It is not in focus in the picture, but it looks to me like there is way more weld than necessary holding that stud on from the inside. That stud in the middle of the sheet won't benefit from being fully welded as it is only as strong the .030 it is attached to, so I would say cut down in those areas if applicable.
    1) What are you using to weld the components on that are not spot welded?
    2) Does it get fixtured in anything that will heatsink, or are you just welding it all together sitting open on the bench?
  12. #12
    Jan 2016
    New York
    246
    6
    66
    Default Warpage from welding
    Quote Originally Posted by johfoster View Post
    The only thing I can think of is the temper of the sheet metal. There is a lot of trashy sheet products out there in the marketplace. When purchasing sheet steel be sure to specify #4 temper for general work. I had a similar problem with spot welded panels. Your spot welds look good.
    Roger
