Hi everyone. I would like to have your recommendation for this case. We have fabricated a pump shaft with 120” of length and 1.756” diameter. The pump speed is 1700 RPM. The issue started when we figured out that the machinist calculation was wrong. 2” shorter than the required size. I have suggested to do stepped shaft by making thread connection ( male & female) with 45 degree bevel to be weld and machined, but it was rejected by our QA due to the shaft will be twisted or broken. Any recommendation please.
