Simple back gauge fingers for press brake
Results 1 to 12 of 12
    Mar 2018
    Idaho
    7
    Default Simple back gauge fingers for press brake
    First post here. I have this brake coming next week and it's never been setup to run. I need to order die material and figure out what to do with the backstop gauge. I know virtually NOTHING about press brakes. I've searched the internet for pictures and info but what I find is a whole retrofit kit for backstop gauges. The parts I will be making (at first) are simple "boxes" and I think I only need stationary fingers for each "station". Is this setup a common starting point and if so where do I find parts to move forward?
    Jul 2006
    Wisconsin
    1,270
    222
    887
    These are what is on mine. They flip up so when the material has a lip or something below them they can get out of the way. Also have a screw underneath to fine tune the ht of each. Another screw and lock screw allows fine tuning the in and out position to match one to another or set a taper. And finally a quick lever screw to lock in place on rail.
  3. Likes potatohead908 liked this post
    Oct 2009
    Portland, Oregon
    3,640
    3893
    1813
    All I've been around are shop made. The ends are milled into a rectangle about .125" by .500" and ground flat.
    Mar 2018
    Idaho
    7
    Thanks for the info Garwood. I'm guessing my methods will be more crude at first then what JP Machining shows.
    May 2008
    Minnesota
    582
    340
    185
    I just use some tool steel blocks bolted to the back gauge. No flipping up fingers. If there is a lip or something that might be caught, I set the back gauge Z very low so that we tilt the flat down slightly to gauge it. And then as the punch descends it flips it clear of the block and does it's thing. In the event it is set wrong, my whole back gauge slide can flip up and avoid catastrophe.
    -Jim
    Mar 2018
    Idaho
    7
    Quote Originally Posted by kb0thn View Post
    -Jim
    This is probably how I will get started. I can see the benefit of having the ability to fine tune depths and heights. The flip up option may not be an issue for now...?
    May 2014
    Hollister, Calif
    21
    6
    I build this for my Di acro 16-24 . I have maybe $150 in it. I like it so munch I ordered material for my other press brake.
    Enjoy
    Sent from my SM-G950U using Tapatalk
  9. #8
    May 2014
    Hollister, Calif
    21
    6
    Some better photos.
    20171004_111454.jpg20171004_111504.jpgAttachment 222104Attachment 22210420171004_121702.jpg
  10. Likes potatohead908, BugRobotics liked this post
  11. #9
    Oct 2005
    10,286
    17357
    5369
    I was thinking something made from unistrut.....
  12. #10
    Mar 2018
    Idaho
    7
    I'm thinking about this stuff to mount the fingers on.
    375
  13. #11
    May 2011
    New Jersey
    445
    9
    141
    Quote Originally Posted by NVelho View Post
    Enjoy
    Where did you buy that stuff, I'm building a new project but along the same lines and I'm not finding cheap stuff.
    Sent from my 2PS64 using Tapatalk
  14. #12
    May 2014
    Hollister, Calif
    21
    6
    You can buy from here. These guys are in Texas. Also do a search on ebay for linear slides or linear bearings and a lot of packaged kits will show up. Gotta spend some time sorting everything.
    Store | ZYLtech Engineering LLC - Zyltech Engineering LLC | Affordable 3D printer, laser engraver and CNC hardware and accessories
