Smith's oxygen regulator
Likes Likes:  0
Results 1 to 6 of 6
    May 2018
    Wisconsin
    Default Smith's oxygen regulator
    Hello all, in need of a little help. It's been 25 years since I've last held a torch and I cannot remember how to read this gauge
    I'm guessing the first red hash mark is 20 psi, where is 10 psi?
    Dec 2008
    New York
    10,059
    2616
    Quote Originally Posted by granitepants View Post
    pressure gage not normally accurate at less than 10% of max reading so below 20 psi you cannot really trust gage anyway.
    typically a cutting torch tip runs 30 to 40psi. you adjust pressure and flow valves based of what you see at torch tip. long hose and many valves causes a pressure drop. even a welding torch tip if you want 5 psi most just set regulator for higher psi and use the torch valve to adjust flow based on what they see at torch tip flame
    Langley, B.C.
    1,662
    335
    970
    Kinda weird the way they've marked that. You would think that each small graduation would be 5 lbs. but if you
    count them you're at 35 when the needle points to 40. I would just average it out and, as has been said, set your
    torch based on what you see at the tip. If you had it to begin with it'll come back to you...
    Dec 2008
    New York
    10,059
    2616
    torch pressure setting aint like its got to be 10.000 psi and flow is often based on pressure drop going through hoses and past valves
    you got a regulator made for torch cutting at 30-40psi. its not the best at what it was never made to do that is maintain a low pressure. its probably on a cheap single stage regulator.
    2 stage regulators often costing over $250. are higher accuracy where you want to set a pressure that maintains that pressure better as the main tank pressure goes down. but now a days most buy cheap <$100. pressure regulators and dont bother to get regulator repaired they just buy a new one. and most if they set for 40psi and after 10 minutes it goes to 39psi many wouldnt even notice it.
    Oct 2005
    14,868
    I'm not seeing the Op indicate "cutting" in any way.....
    Jan 2019
    Tennessee
    456
    139
    120
    10 psi is smith micro torch territory. Unless you are running a machine torch counting gas in micrograms per inch of cut just get close plus 5 'for the pot' of recommended pressure for tips.
