Stainless Steel Pickling ?
Results 1 to 8 of 8
    Sep 2004
    NH
    1,162
    103
    Default Stainless Steel Pickling ?
    I have recently silver brazed some delicate assemblies of 316 stainless and hypodermic tubing. In the past I have pickled similar brazements in stuff called Sparex which is a common jewelers pickling compound but wonder if thee is something better for stainless steel. The Sparex is sold in granular form and dissolved in water and then kept warm in a small crock pot. I do have muriatic acid, some sulphuric acid and maybe some nitric acid on hand. I wonder about citric acid and maybe even acetic acid (vinegar) as possible pickles. What do folks suggest? Thanks for any useful replies!
    Oct 2010
    Oregon
    5,389
    4977
    2010
    Look up "passivate" for stainless. Among a great many other things, citric acid has been used for small-shop low-hazard passivation.
    Jun 2016
    New York
    1,891
    1232
    905
    Something to consider is after brazing, (unlike after welding), you are dissolving flux as a big part of the clean up, so the proprietary “weld cleaners”, the passivating solutions, and other post-weld cleaning procedures and processes are going to come up short.
    Warm sodium bisulfate solution (spearex) is hard to beat for that. After pickling, one of the other processes could be used to further clean and passivate, but if it is for medical, I’d think it would go to an electropolish anyway.
    Dec 2014
    Arizona
    369
    39
    63
    For small stuff like that I've used a mix of a little nitric with hcl for diy picking. For just passivating I've used straight hcl, just don't leave it in either too long, it will turn black and ruin your parts, keep an eye on it. Once the surface gets a dulled, matte finish I pull out.
    Sep 2004
    NH
    1,162
    103
    Excellent info - thanks!
    I typically boil them in water post brazing to dissolve the flux but I need something to remove the oxide layer. So a pickle bath is next, some polishing with rouge and then ultrasonically clean them. Muriatic is HCL correct?
    Mar 2004
    Edison Washington USA
    10,606
    1041
    5667
    commercially, stainless passivating and polishing is done with phosphoric acid. its a lot less dangerous than sulfuric or HCL or nitric. It works fine.
    Job site stainless cleanup has been done by electropolishing with citric acid for decades now.
    Again, less likely to burn thru to your bones, or even leave holes in your jeans.
    CitriSurf Citric Acid Passivation | Stellar Solutions - Stainless Steel Passivation
  7. Likes memphisjed liked this post
    Aug 2012
    California, Central Coast
    4,687
    2330
    1898
  9. #8
    Jun 2016
    New York
    1,891
    1232
    905
    Quote Originally Posted by Gazz View Post
    “Muriatic” is bull, and should be tossed out with the lead paint and the uranium glazes and the X-ray foot measuring rigs, yes, it is hydrochloric acid, and that and the wolmanized lumber and the Nirod gets you absolutely nothing.. pass me the Kleenex and get yourself a Tampex..
  10. Likes rcoope liked this post
