What's the minimum feature size that can be achieved in a stamping press? Is it just a matter of how finely you can make the dies? I'm thinking about a part with a sort of sawtooth pattern where the teeth are 0.005" crest to crest. Inside corners are radiused 0.003", so dies can be made with the higher end wire EDMs.
The material is generally 0.010" or thinner, brass and aluminum.
Thanks.
Thanks.
