Stamping Press Minimum Feature Size?
Results 1 to 5 of 5
    Dec 2011
    289
    41
    111
    Default Stamping Press Minimum Feature Size?
    What's the minimum feature size that can be achieved in a stamping press? Is it just a matter of how finely you can make the dies? I'm thinking about a part with a sort of sawtooth pattern where the teeth are 0.005" crest to crest. Inside corners are radiused 0.003", so dies can be made with the higher end wire EDMs.
    The material is generally 0.010" or thinner, brass and aluminum.
    Thanks.
    Jan 2009
    Missouri
    88
    134
    24
    Quote Originally Posted by Radar987 View Post
    Thanks.
    Reference 'fine blanking' an example will be found in small electronic terminals.
  3. Likes AD Design liked this post
    Sep 2010
    Vancouver Canada
    862
    618
    296
    Quite a bit in the new NYC CNC video tour of Superb Manufacturing. Going from 100 million to 1.3 billion parts per year can happen when you start making a lot of small connectors with features on this scale.
    YouTube
    Oct 2017
    513
    123
    133
    Looking at all of the stamped parts for electrical ICs and connectors, I have no doubt this can be done reasonably.
    Sep 2015
    Tennessee
    472
    240
    360
    It's not whether it can be done or not. It's been done for years.
    Your example does not include tolerances. So, "reasonable" depends. You can have it quick, cheap, or accurate; pick two.
    As far as the smallest feature size a stamping die can maintain? A feature that references itself, like you mentioned with a sawtooth pattern? I wouldn't expect anything more accurate that 1/10th T
