Steel that won't weld? - Page 2
Page 2 of 2 FirstFirst 12
Results 21 to 34 of 34
  1. #21
    May 2011
    New Jersey
    750
    19
    261
    You can search the forum and I am sure you will find a thread where someone says a spider crawled inside there when the torch was just sitting around and melted to the head.
  2. #22
    Mar 2013
    Cerritos, CA
    408
    134
    153
    I dug into my scrap bin and found some rusty/dirty sq. tubing to test and had no problem welding with my first Miller (330BP) purchased in 1971.
    Attached Thumbnails Attached Thumbnails 4b096a49-a056-4316-b231-859b2ce5ee3b.jpg
  3. #23
    Aug 2010
    Santa Cruz, CA USA
    208
    406
    76
    Looks like a gas problem to me too. Are you welding in a breezy area? Any chance the gas is being blow away?
    With that said you really should clean with acetone before welding, also with that level of contamination you'll likely need to grind off the bad weld before re-welding as well. Just my 2 cents.
  4. #24
    Jan 2015
    Michigan
    421
    167
    I think its a gas problem, I had a welding friend tell me his spool gun wouldn't work for aluminum, when he would pull the trigger the gas would come out, but as he welded the regulator couldn't keep a steady flow of gas. So try a new tank of gas and a different regulator.
  5. #25
    Oct 2005
    22,565
    Quote Originally Posted by Portable Welder View Post
    These come in handy for finding flow problems:
    Torch Gas Flowing Meter Tester Argon Flowmeter For Mig/Tig Brand New Durable | eBay
  6. Likes gary-sc liked this post
  7. #26
    Sep 2010
    Oklahoma City, OK
    5,650
    1094
    2474
    Swapped in a fresh Victor reg, issue persisted.
    Quote Originally Posted by gary-sc View Post
    Always! I learned how to weld from pipeliners. Weld, clean/grind, weld, repeat....
    Edit- just to be sure it wasn't the equip, I ordered a new CK20 setup. Can't have too many torches!
  8. #27
    Jul 2019
    Connecticut
    34
    64
    10
    Quote Originally Posted by hvnlymachining View Post
    I had this same problem not too long ago, ran great then went south all of a sudden. Turned out to be the argon. As I neared needing a refill, some unknown gas made it to the torch, caused porosity and immediate oxidization. The cylinder had gas contamination bottled right in. Switched bottles and the problem disappeared.
    This has also happened to me on two different occasions. swap the tank out with a different one and see if the problem persists
  9. #28
    Sep 2005
    Northern California
    1,138
    191
    The last batch of seam out tubing I bought had a waxy corrosion preventaive / drawing lube on it. Clearly the application process was a full dip as it was extra heavy on the inside. Weld prep (GTAW) included cleaning the inside of the tubes carefully.
  10. #29
    Dec 2018
    Indiana
    197
    43
    If I run into to issues like that first thing I do is to grab a clean piece of stainless scrap. Keep welding, torch and gas settings all the same then put in a freshly ground piece of tungsten and without wire just make a big spot weld. Just stop the pedal and hold is there for 5 seconds then left off and hold the torch still until post flow is done. If the tungsten doesn't look perfect(no color change) and freshly sharpened after then you know its not the work piece but your equipment.
    Doesn't solve the issue but helps cut down on chasing your tail.
    Also don't be afraid to run over the joint hot and fast without wire to burn off nasty junk. Don't need to actually melt the metal doing it just get it hot enough to burn stuff off. Don't forget to drill some holes in the tubing so you have a way for gas to escape.
  11. #30
    Mar 2009
    6,423
    125
    1247
    Quote Originally Posted by Cole2534 View Post
    Was fabbing up a small frame and I can't get this steel tubing to TIG weld for shit. It pops and spits and won't take a good bead at all,
    When it gets that bad, I regrind the point and use S.S. rod.
  12. #31
    May 2011
    New Jersey
    3,357
    372
    1910
    Quote Originally Posted by rons View Post
    347ss rod is my filler of choice and E3 (purple) tungsten is my electrode of choice.
  13. #32
    Mar 2009
    6,423
    125
    1247
    Quote Originally Posted by moonlight machine View Post
    Everybody will flame me for this, try 308 rod. I have run into the same issue. Once it was argon, changed the bottle and it all went to shit. Change the bottle again and all is good. 308 is SS but it works a treat when you have issues like this.
    Not this body. I have a heavy bundle of ER308 and always like using it. In a way the stuff inspires more confidence. One less thing that could screw things up ...
  14. #33
    Mar 2013
    Cerritos, CA
    408
    134
    153
    It's been a few weeks - what was the solution?
  15. #34
    Sep 2010
    Oklahoma City, OK
    5,650
    1094
    2474
    Quote Originally Posted by Lanso View Post
    Increased cleanliness. Usually a bright sanded finish means absolutely dead clean....until your flap wheel absorbs some oil. Application of acetone and clean rags did the trick. I also ditched the dirty buffing wheel.
    Sent from my SM-G981V using Tapatalk
  16. Likes DrHook, sfriedberg liked this post
