Sticky solenoid valve on Lincoln TIG 300
Results 1 to 3 of 3
    May 2002
    South Central PA
    13,447
    2176
    3372
    Default Sticky solenoid valve on Lincoln TIG 300
    I woke up my old Lincoln TIG 300-300 today after a long sleep. This is one of the old gray beasts circa 1976. The argon valve doesn't open every time the arc is started. If it's still open on the post flow timer, it stays open when welding, but when I first press the amptrol, it might take 4 or 5 hits before it opens, which is really annoying at best. Is this likely just a sticky valve, or is it electrical?
    Aug 2015
    Illinois
    1,349
    971
    576
    Disconnect the solenoid leads and use external power to test the valve. That should tell you if the problem is the solenoid valve or electrical.
  3. Likes Mud liked this post
    Aug 2010
    Minnesota
    1,984
    150
    1464
    Start off by opening the case and blowing all the dust out... The valve is usually right where the main line connects to the machine. Grab a meter and see what triggers it and the diag should be very simple.
  5. Likes Mud liked this post
