oceanobob
- May 18, 2014
- Oceano, CA
Took on a fab job for drilling & tapping 36 (thirty six) 1/2-13 holes in piece of 5/8" thick hot rolled plate: Flat Bar Dims 4" wide by 75" long by 5/8" thick.
Plate is about 55ksi yield - meets A36 as well as Gr50. Cold Roll too much $ as material is only 12' long, drop is too big.
Thinking of this method:
Sandblast the plate(s) to remove the mill scale
Machine avail is a vertical knee mill with a DRO. Has the larger table.
Holes are to be three repeating patterns of twelve each per pattern, the pattern O/A dim is about a little less than 20" distance.
Use 27/64" stubby screw machine drill bit to make the hole (following the pilot drill). Was wondering if I should hand (27/64") ream the hole to make sure it is round?
Lightly chamfer the start of the hole; use the tapping head with either a new spiral H3 tap or a new gun (spiral pointed) H3 tap.
Twelve holes thus made: swap the drill to the tap head and go back (DRO) and tap them.
Relocate the plate for the next group of twelve, repeat above.
They wanted one plate yesterday, but they really want three plates done.
