TIG Mild Steel with Stainshield?
Results 1 to 11 of 11
    Dec 2005
    Wisconsin
    2,000
    496
    665
    Default TIG Mild Steel with Stainshield?
    I have a gas bottle here that says Stainshield. I think it's mostly Argon, an Argon regulator fits the bottle. Not sure if this was for TIG or MIG. Anyway, can I use this gas to TIG mild steel?
    Jan 2005
    The Netherlands
    6,815
    378
    2022
    Try it and report back
    Peter
    Oct 2005
    22,538
    Dec 2005
    Wisconsin
    2,000
    496
    665
    Quote Originally Posted by Peter from Holland View Post
    Peter
    I hope to this weekend. But since I don't know how to TIG weld just wondering in advance if I'll be able to blame the crappy results on the gas or if it's entirely me.
    Jul 2013
    atlanta, ga
    358
    29
    291
    I’ve TIGed mild steel with 75/25 Argon/CO2. It’s definitely dirtier, but it’ll work.
    My guess is that whatever comprises the “Stainshield” gas in question will be a lot cleaner than 75/25. I imagine it’s a tri-mix gas, probably mostly marketed for MIG-welding stainless alloys. Argon primarily, with Helium and CO2 making the balance, sometimes a tiny bit of oxygen instead of the argon.
    Be safe
    Jeremy
    Oct 2013
    South Dakota
    366
    4497
    152
    I found two different versions on Google, but both should work for stainless, from what I could tell. If you are a Tig beginner, you can ALWAYS blame the gas...
    Feb 2007
    St. George, Utah
    1,425
    945
    996
    Quote Originally Posted by jermfab View Post
    . . .I imagine it’s a tri-mix gas . . .
    This one is Argon with 1.5% O2. I suspect there is enough oxygen to have a detrimental effect on most ordinary steels. It'll be interesting to see how it turns out.
  8. Likes Matt_Maguire liked this post
  9. #8
    Dec 2015
    Illinois
    670
    223
    405
    With TIG the gas isn't just shielding the weld, it is also shielding the tungsten. My experience TIG welding with 75/25 resulted in a tungsten ruined the length extended from the collet, not just a bad weld. In fact I found this out when I was showing my brother in law how to TIG weld. It turns out it wasn't his technique ruining the tungsten it was the gas he was using.
    You can give it a try but if you are trying to learn I would use the correct gas and remove that variable.
  10. #9
    Oct 2011
    West-Central Illinois, USA
    1,427
    2277
    674
    The Stainshield mentioned are active gases for mig/mag machines. The middle letter means inert or active gas.
    TIG only uses argon($) argon/helium($$) or helium($$$$). If you put Co2 or O2 in the shield it eats the tungsten and reduces the weld puddle of some iron% and carbon% while leaving some iron oxide behind.
    Good luck,
    Matt
  11. Likes BT Fabrication, DrHook liked this post
  12. #10
    Jul 2013
    atlanta, ga
    358
    29
    291
    Quote Originally Posted by Gordon Heaton View Post
    I thought about that a bit more after I made my first response. Oxygen… and it’s oxidizing effect… will likely play hell with both tungsten electrode AND the weld. I would definitely assume I’d be dressing the tungsten regularly. Likely after every weld.
    I do remember clearly the first time I learned that you could even make a TIG weld with 75/25. I came back to do some contract work in a shop I had worked at previously. The guy I trained to replace me had taken over and it was his shop at that point. I noticed that I was having trouble with arc wander and cleanliness and finally troubleshot the issue to the gas bottle.
    When I asked my replacement why that tank was on the machine his response was: “you taught me to use 75/25 for mild steel…”
    God knows how much mild steel he had TIG welded on 75/25.
    Knowing that it COULD happen, I’ve done it once or twice since… but it has definitely been an “any port in a storm” option… definitely not ideal.
    Be safe
    Jeremy
  13. #11
    Nov 2019
    CANADA
    Ontario
    687
    1104
    167
    there is 1.5% oxygen in it, it will react with the weld pool to make mig welding hotter and faster. but will make it dirtier to weld and 99% sure it wont turn out well for TIG.
    in mig it works well for mild steel with the oxygen, my big mig i have a tri blend of gasses 92.5 argon, 5% co2 and 2.5% oxygen for thick metals.
  14. Likes adh2000 liked this post
