byawor
Hot Rolled
- Jun 23, 2012
- Regina. Sk. Canada
Having custom diesel tank built from 10 guage aluminum, one guy wants to TIG it another guy says no problem using Mig spoolgun. Which is the better choice?
Bob
Bob
Depends, how do you want it to look, are you talking a professional welder with both processes?
As if its custom, I'm assuming its going to be looked at, thus its all in the eye of the beholder. Both processes will get the job done, TIG, In my humble opinion, gives a nicer "look". However, a lot of this look is the welder.
Short answer, it doesn't matter too much, but personally I think a TIG process looks better on the outside.
My feelings as well. Either will work but given a choice, especially if looks are a factor, I'd go for the tig welded unit. Put it this way: A "decent" weldor using a tig will produce a better result than a "superb" weldor using a gun. If the guy using the gun is "really" good he can come close to the same result you'll achieve with a tig; if he's only a "decent" weldor the results will likely be inferior to what you'd get with a tig. This applies to both the appearance and integrity of the tank...
No "better" choice.....best choice is having it done by someone that knows what they
are doing......eh?
Mig will be at least 2X as fast. 4x?? 8x ????
Is it a show piece? Will you polish and pinstripe the tank ???
A welder that can use a spool gun should have no problem.....
You can inspect and approve the work before you pay for it and accept it.....I hope??
dk
Guy says he will start with mig on inside welds then do outside tig if I prefer. Seems like a good option. This does not have to be real pretty but decenct would be nice.
Bob
??? I am confused...
How much inside welding? Is there going to be baffles in the tank?
What is the shape and size of the of the tank, volume?
All the big aluminum tanker trailers are mig welded. If the mig machine has a pulse option you will almost never have to worry about burn though, I have it on my XMT304 and it is pretty great. We have a 350MPa at work and they do all sorts of stuff with that and you get very clean welds.
Macona, you mentioned 350MP ... Is that the lincoln mig machine? That is the machine I want to use the pulse feature to mig carbon steel with silicon bronze wire. I'd use a push pull gun. Are the pulsed mig welds you make pretty? Thanks for any info you can offer. I'm making high end steel furniture that is only clear coated when finished. I'm wanting to switch to SiBr for looks and have determined this is the machine I want.
Notice
