Tips for bundling rounds for sawing?
Results 1 to 14 of 14
    Sep 2010
    Oklahoma City, OK
    5,045
    908
    2117
    Default Tips for bundling rounds for sawing?
    All,
    Occasionally I have to do small production runs and this 1 by 1 saw cut stuff sucks.
    Material is stressproof, diameters 1" - 1-1/2", 2-4 at a time.
    The same has hydraulic downfeed, coolant, and plenty of HP but I cant figure out how best to bundle them. If it were cold-rolled I'd weld the ends, but this material doesn't like welding. (Although it may suffice for this task?)
    So what are some trick you use to keep bundled cuts from eating saw blades?
    May 2002
    South Central PA
    13,956
    2460
    3719
    Squeeze between 2 big Vblocks. I've done 12+ lengths between a pair of 4.5" Vblocks.
    I've Tigged Stressproof. It isn't strong, but it welds.
  3. Likes michiganbuck liked this post
    Sep 2010
    Oklahoma City, OK
    5,045
    908
    2117
    It'd probably strong enough to keep the lengths even. Maybe that and some chain type vise grips.
    Jan 2019
    Tennessee
    553
    177
    147
    tigerstop, foot pedal, one at a time.
    Jan 2007
    Flushing/Flint, Michigan
    8,968
    483
    7382
    This may be so very crude but...zip ties pulled down tight with vise grips
    Bob
    Dec 2013
    montana
    355
    37
    88
    shrink wrap has worked well for me in the past. i just wrapped the whole length tight and had no issues. it’s easy to remove once things are cuts also.
    Nov 2007
    marysville ohio
    9,958
    2839
    6638
    Quote Originally Posted by climb-101 View Post
    I tack the ends of stressproof all the time, it welds plenty good enough to hold while sawing. I use a hose clamp or three to stack 4 aluminum bars for sawing. works a treat.
  9. #8
    Apr 2007
    Pillager, MN
    5,938
    1918
    5496
    Weld 'em...............do it all of the time. 1144, 12L14, 303SS.........they all don't "weld", but they weld well enough to hold them together for sawing.................
  10. #9
    May 2011
    New Jersey
    654
    14
    222
    If I'm cutting a lot, I try to slide a piece of square tube over it to hold the pieces from rotating when moving between cuts.
    If your cutting more then 2 pieces, welding is the only real option. You can also use shrink wrap and then very heavy packing tape throughout the length. Or painters tape then packing tape, just to keep residue off the material.
    If you cut rounds say 2w x 2h, you have to be very careful as the clamp doesn't hit both pieces of material. I use a piece of hard rubber at the clamp to help grab each stacked piece.
  11. #10
    Jul 2007
    Hampton, Virginia
    2,500
    202
    204
    I found an easy way is to use home brew "V" blocks made by welding heavy angle to heavy flat then thread old leather belting between the rounds only where clamped.
    For the leather belting I look for old leather work belts every time I visit a second hand thrift shop. I have a box full. It's great for all clamping needs when you want the stock to hold firm without making marks.
    Also keep a few heavy angle and flat bar drops out of the scrap bin in case we need a quick "V" block.
    Walter
  12. #11
    Dec 2012
    Se Ma USA
    1,777
    144
    982
    I cut a lot of .625 round stock into short pieces. Hyde-Mech automatic H 14A. I removed the moving jaw faces and made some "L" jaws that are almost as wide as 5 bars at the bottom of the "L". Upper leg of the "L" is slotted for adjustment with longer screws in the stock jaw holes. Keeps all 5 round bars side by each and can adjust for other sizes if needed. More important is that almost any other thing I cut on that saw can be done with those jaws in place. They are just high enough above the table for the .625 stock to slide through.
  13. #12
    Aug 2011
    NE Wyoming
    63
    32
    We use the chain vice grips all the time here. You get the added benefit of having handles to pull the bundle with also.
  14. Likes Cole2534 liked this post
  15. #13
    Jul 2004
    Southeast Michigan
    6,711
    253
    1623
    I don't know what it's called, but the black steel strap for shipping works.
    Once you have a series of straps on them, the vise has something to push against.
    Having a top clamp bar helps too.
  16. #14
    May 2006
    Seattle
    2,151
    51
    436
    I make top and bottom bars with holes spaced so the pieces just barely fit between the clamping bolts. I've done up to 15 1" EMT tubes at once before. - metalmagpie
  17. Likes Mud, Cole2534 liked this post
