Mikey D
- Jan 4, 2006
- Good Ol Sunny Arizona
Good evening. I know this sounds like something a kid would do but here goes nothing.
I'd like to remove the weld from inside a piece of 2" sch 40 steel pipe. The end result will be an air cylinder.
Before anyone says don't do it or buy some DOM, this has to be done on the cheap (read free!) I'll be making something like 5 or 6 of them to use on a "Mad Max" vehicle. It is more of a parade vehicle and the cylinders will not be used for holding, just for slamming something against a spring into a latch - so it does not matter if the piston seal is perfect. I'm looking at using 50-60 psi and welding in the ends in place. I might not even use an o-ring on the piston if I can get away with it.
I have a #1 Bridgeport, an old SB 9" lathe and a 13 x 40 jet with which to do this. I'm looking at a cylinder length of around 16" and would like some simple tool like a counterbore that I can put a shaft extension on and just run down the inside of the pipe. I know the pipe is not terribly round and if the tool surfaces a bit of it that would be OK as well. I do not want to use a boring bar - I do not have the $ for one that large and I don't need it that good.
I teach welding at our local HS and community college and the kids are really into this project & I hope to be able to get it done. Additionally, while I'd like anything I build to last forever - I doubt this thing cycles a thousand times in it's life.
As a last thought - after I get this process ironed out, I'm going to make a large one out of a piece of 8" pipe - 24" long, so keep that percolating on the 'ol idea burner as well.
Thanks in advance for your advice!
Mikey
Mikey
