Turret Machine; Battery Always Low Despite Replacement
Likes Likes:  0
Results 1 to 3 of 3
    Oct 2019
    PHILIPPINES
    5
    Default Turret Machine; Battery Always Low Despite Replacement
    Hello! Does anyone also encountered when a machine's lithium battery is always, frequently or easily gets low power? Any suggestions on how to troubleshoot this?
    We have a turret machine, a PoNZ FC 1250E-32 2.5, where the battery for its X&Y axis easily gets low power. We have replaced the battery, several times already but the two sets recent replacement battery (6V) did not last for a month.
    Steps we conducted so far:
    1. Rebooting the turret machine, resetting the clamps. Which temporarily fixes the alarm.
    2. Replaced the battery set, twice in less than two months. Battery set is rated at 6Vdc (4pc - panasonic lithium batteries).
    3. Reported to our tech, but no clear solution after the 2nd battery replacement.
    Alarm on turret controller
    Virginia
    27,347
    7561
    8525
    Quote Originally Posted by kurukukuk View Post
    Battery is "low", just puts shims under it?
    Lithiums are "secondary" cells as a general class. Meaning they expect to be recharged, not used-up and discarded.
    "From a distance", EITHER/BOTH:
    - whatever is MEANT to be recharging it whilst running is not.
    - there is more drain on it when idle than planned-for.
    The second one is the more likely.
    Not ALL Lithiums are in a circuit with charging capability if the drain is so low they last a long time.
    Dunno how hard it is for YOUR "Tech" to find an excessive drain and sort the cause.
    My experience in the Philippines was mostly with PLDT & ETPI. Both of them surely had smart enough folks. So should your firm. No shortage. Y'all export good techs!
    If changing batteries doesn't work? Try changing the tech.
    Oct 2019
    PHILIPPINES
    5
    Sorry, but i did not understand this.
    IMO, changing the batteries would definitely not work, but we still proceeded as suggested by the tech.
    And i am looking forward to working with a new tech.
