Joe Miranda
Titanium
- Oct 19, 2004
- Elyria Ohio
I have read that guys are using CO2 with their flux core set up for improved weld appearance and wire deposition. Have any of you guys tried it and if so is it worth it? Thanks.
Wow...ummm...like...I mean...I turn the machine on and pull the trigger...if the stuff sticks together - great - success!
Been considering moving my MIG to a dualshield setup. What wire yall recommend for general purpose fab? I currently use .035" NR-211-MP.
Small, 180amps.How powerful is your machine? .045 is way more common and easier/cheaper to make. I use pretty much 2 wires, both esab. Coreshield 15 (similar to your 211) and dual shield 7100 ultra. The 7100 can use either straight co2 or mix gas, both in .045 larger jobs may see 1/16" 7100 but I dont really see much difference than the .045. Other common one I use would be 1/16" coreshield 8 but only for structural in windy environment.
Small, 180amps.
Minimum recommended Lincoln? Back story is that I've been approached about ornamental iron work, gates and such. Some will be pretty heavy and reduced splatter is always nice so I thought I'd see if I could move to Dualshield.You might need a bit more of a machine to get a dual shield to play right...
My friend runs a BPVC shop. Maybe I could borrow some gas and wire to give it a try.I know esab makes the 7100 ultra in .035. Might barely work, try to get a 10 lb spool or will your machine only take 8" spools?
Notice
