Using incorrect Gooseneck punch, Press Brake
Results 1 to 11 of 11
    Jan 2015
    Michigan
    363
    161
    Default Using incorrect Gooseneck punch, Press Brake
    Along with a new Press Brake, I ordered a Gooseneck punch, I told the guy at R.K. ( The company that makes the dies ) not the press brake manufacturer, that I want a Gooseneck punch that will bend 1/4" material.
    He told me that I would be okay with a G-9 die, doing a little research... ( Looking at their brochure )it says the die is rated for 9 ga. material, when I questioned him on it, he said not to worry.
    So my question is: Do any of you press brake operators use a G-9 die to bend this... In his defense,I did tell him that this is not something I will be doing all the time, usually it will be 10 ga. or less.
    Sep 2010
    Vancouver Canada
    663
    432
    212
    More formally knowledgeable people should chime in here but I believe the bottom die and the overall rating of the press vs the length of your bend are what matters, not so much the upper die.
    Jan 2014
    GA, USA
    19
    5
    They recommend a 3mm punch tip radius for 1/4” material. If the punch has that you should be ok.
    Jul 2004
    Southeast Michigan
    6,361
    227
    1365
    That's what size we had at VBS Dave.
    Glad to hear you got a press brake!
    I need to get ahold of you, I need some shearing done.
    Jan 2015
    Michigan
    363
    161
    Snowman, I wont have the new brake until the beginning of the year... it seemed to me that we used to do 1/4" with that punch, I just don't know what punch it was.
    Mar 2009
    Nebraska, USA
    293
    65
    102
    Keep the width of the bottom v die as wide as you can run and air bending you should be fine.
    Regards
  7. Likes Blacktooth liked this post
    Jul 2004
    Southeast Michigan
    6,361
    227
    1365
    Quote Originally Posted by Portable Welder View Post
    Yup...for a full length bend it had to be switched to the 3" die, but that wasn't the fault of the punch.
    Generally the punch was changed for 3/8" and up.
  9. #8
    Sep 2015
    Tennessee
    408
    208
    303
    Is the inside of your bend cosmetic? i.e. does it need to look really purdy? If no, then that punch will be fine.
    More important is your die. The V should be 6 to 10 times wider than the thickness of your material, with wider being better.
    Source: setup and programing CNC press brakes before I became a tool & die maker
  10. #9
    Jan 2015
    Michigan
    363
    161
    Typically, The die that I will use on a given material will be 8x material thickness.
    I don't understand why you asked about what the inside radius will look like, I assume the gooseneck will show more witness marking.
  11. #10
    Jul 2004
    Southeast Michigan
    6,361
    227
    1365
    It's just cosmetic issues. As you know, the punch nose radius is one of the determining factors in the radius of the bend, as well as the witness marks.
    It sounds like you got exactly what you need for probably 99% of your work. It would take a REALLY picky customer to start pointing out bend radius.
    Think about a commercial kitchen, doing inside corner pieces out of stainless or something.
    It's within your capabilities, but likely not the average customers requirements.
  12. #11
    May 2011
    New Jersey
    445
    9
    141
    There are many things that go into selecting a correct punch for which material. The biggest thing to keep in mind is how much tonnage the punch is capable of holding. If you exceed that, that's a major problem then die radius or angle. Also don't push the die past it's limit, so air bending is always recommended.
    Sent from my 2PS64 using Tapatalk
