Using ox propane with a ox acetylene rosebud
Results 1 to 16 of 16
    Nov 2002
    Western ,Oh ,usa
    514
    273
    30
    Default Using ox propane with a ox acetylene rosebud
    I converted over to ox propane for cutting on my Harris 85 torch handle, local Harris distributor said changing the cutting tip was all I needed to do , and it works well for me.
    Now I really need to use the rosebud (ox acetylene rosebud rosebud) , for just one job and I don't have acetylene tanks any more. Would it be OK to just
    light up that rosebud with ox /propane ? What would be the probable outcome ?
    David Lawrence
    Jan 2005
    The Netherlands
    6,438
    334
    1834
    What I was told is to drill the holes twice as big just a few mm deep
    That will preheat the propane somewhat
    Peter
    Nov 2013
    Eastern Massachusetts, USA
    6,593
    5711
    6131
    I'd be interested in the outcome because while I still have acetylene there may come a time where it is so restricted within city limits that only commercial shops will be allowed to have it.
    I did a quick search and this tip can be used for either according to the manufacturer so perhaps yours can be as well.
    https://www.northerntool.com/shop/to...6846_200606846
    I also found this older thread on PM.
    Settings for using a rosebud?
    Oct 2011
    CANADA
    British Columbia
    659
    71
    426
    The flame speed of Propane is much slower than acetylene. Yes you can safely use propane in an acetylene rosebud but you will have trouble lighting and the flame will be prone to blowing out.
    NEVER use acetylene on a tip or rosebud that is designed for propane. The acetylene will move up inside the torch and melt the torch or cause other bad things. I have seen a propane cutting tip light up like a halloween sparkler and start to melt before we got things shut down.
    Aug 2012
    California, Central Coast
    5,009
    2368
    2056
    I use propane with acetylene rosebud all the time. It works great, I even like it better than acetylene, it does not heat and burn the surface as fast. It is a little different to light but a tiny bit of oxy turned on to start makes it easier. It is a little diferent than acetylene as far as adjusting the flame.
    Propane is not as hot, so if you use the rosebud for a longer amount of time it wont overheat the tip and start popping like acetylene will.
    Nov 2002
    Western ,Oh ,usa
    514
    273
    30
    Lit up stock 6 holes @ 38 thou burned ok. Drilled out to 1/16 and flame looked better more robust and even.
    Thanks for all the insights.
    David Lawrence
  7. Likes JHOLLAND1, PlasmaOnTheBrain liked this post
    Jun 2016
    New York
    1,963
    1394
    936
    Quote Originally Posted by lalatheman View Post
    David Lawrence
    be sure you mark that tip modified for propane! engrave with dremel or other permanent marking.
  9. #8
    Nov 2013
    6,593
    5711
    6131
    David Lawrence
    If someone who has both types could measure the holes we'd have a good starting point.
  10. #9
    Oct 2005
    20,126
    Quote Originally Posted by Scottl View Post
    A propane cutting tip is very easy to identify, their 2 piece construction….
  11. #10
    Dec 2012
    AUSTRALIA
    3,822
    18
    1342
    Lighting up a torch is very easy if you have some oxygen in the flame too.....I can light up a oxy /fuel cutting nozzle instantly ,where some take ages to get the gas lit....I used to have my big rosebud explode regularly ,cops came a couple of times ,then I could get away with shooting my 22 pistol ,shorts only,at pests.
  12. #11
    Jan 2005
    The Netherlands
    6,438
    334
    1834
    Yes indeed and the inner part is a bit shorter as the copper shell
    So with drilling the holes of your rosebud a bit bigger you get the same idea
    Peter
  13. #12
    Oct 2005
    20,126
    Quote Originally Posted by Peter from Holland View Post
    Peter
    I recall that feature (now that you mentioned it) I wonder if the rosebud should be chucked in the lathe as well to counterbore that area.
  14. #13
    Jan 2005
    The Netherlands
    6,438
    334
    1834
    You could also linebore it
    Drilling it bigger say 2,5mm about 4 mm deep thats where I would start
    Peter
  15. #14
    Dec 2012
    AUSTRALIA
    3,822
    18
    1342
    The idea is to slow and de-streamline the gas flow ,because the gas has a slower reaction speed than acetylene.......Ive see some nozzles with hundreds of holes ,precision drilled ,to get gas velocity down to near zero for glass blowing.
  16. #15
    Oct 2005
    20,126
    [QUOTE=john.k;3517417]Lighting up a torch is very easy if you have some oxygen in the flame too.....I can light up a oxy /fuel cutting nozzle instantly QUOTE]
    Yup, I do it all the time.
    "Hot starting" is what I call it.
  17. #16
    Jun 2007
    Vancouver Island, B.C. Canada
    1,966
    47
    242
    Quote Originally Posted by Rob F. View Post
    If your acetylene rosebud is popping it is not overheating it is running out of acetylene, up the pressure to 10 or 11 and it will be fine.
    The pops are pretty loud, scared the crap out of me the first time it happened. If your rosebud is large it may require a larger tank to provide enough gas flow, a B tank is not going to run a rosebud very well.
  18. Likes digger doug liked this post
