bobinoregon
- Dec 18, 2018
Have some half spheres, hollow 1mm wall, that need to be welded into spheres. 410 & 430 stainless. If it were just a few I'd tig them.. but 100 plus. Don't want to spend days on a tig welder. I was thinking I'd take an old chicago electric welder that is just collecting dust, attach some copper pipe to the leads and use it as a "spot" welder to weld the seams.
Copper pipe would be slightly smaller than the sphere, flare the end a bit.. should provide enough continuity that the two halves of the sphere have the most resistance and viola a resistance weld along the seam. If the cheap chicago electric can't do it then I could use a 200+ amp arc welder.
Anyone see any issues with this setup? Or have any input? Thanks, Bob.
