rons
- Mar 5, 2009
- California, USA
The supply store keeps the bundles of silver solder in the back room due to it's high price. A plastic container of rod is about $80 each. Is there any particular variety that is better/worse. I'm thinking about joining stainless 316. If it was not so thin then a weld would do. Anyway, I have a bunch of Mapp gas cylinders and thought about getting into it as a alternative to welding.
Is any acid based flux good enough?
How do I know if the heat is being applied correctly.
I have a butane torch and was wondering if it can be used to join small parts with silver solder. Such as insert nuts or little studs to a thin sheet.
https://www.amazon.com/Blazer-GB4001-Stingray-Butane-Torch/dp/B01M0EZKSY
(just a diversion from breaking out the Miller stuff and hoping I have a good day)
