Phil in Mt
Cast Iron
- Jan 27, 2003
- missoula, montana
I have been building a jeep from a pile of old parts, The frame I used was boxed from the front to the back (82 cj5) The low parts of the frame were real rusty and I had to cut the bad parts out and weld in new iron. What I am thinking about doing is to filling the box in with the spray foam you use to set doors and windows. I am thinking that the foam will coat the steel and stop dirt and water from filling the box full and starting the rusting all over agin. The test I done on the foam it seems to be closed cell and does not hold water. the only down side is if I would have to weld on the frame after the foam is sprayed in. Anyone have a better plan?...Phil in Mt
