Waterjet Tank Temperatures
Likes Likes:  0
Results 1 to 4 of 4
    Jan 2009
    California USA
    38
    Default Waterjet Tank Temperatures
    Lately I've done a couple of projects where the machine is cutting for long periods of time and of course the tank gets pretty hot which I would imagine could alter the tolerances of the machine. It got me wondering if anyone out there who does a lot of cutting makes an effort to control the water/machine temperature. I've seen pictures of companies doing seriously thick plate cutting which must take all day and night to complete and I would guess the plate would grow from it's cold state altering the tolerance of the part.
    Feb 2014
    North Kingstown RI
    116
    13
    68
    Quote Originally Posted by alexf View Post
    Given the tolerances we typically aim for on our WJ, tank temp has never noticeably altered our finished blanks. We do however filter and reuse our tank water for cutting (Through a multi stage ebco filtration system) we then run the scrubbed water through a large chiller before it goes to the intensifier pump. You don't want your pump getting too toasty...
    Jun 2006
    Near Seattle
    5,284
    3890
    1607
    On my globalmax the temperature of the tank water can't actually directly affect it - the machine kinematics aren't actually in contact with the tank. (As the water heats it would of course heat the environment around it, and that would eventually matter...)
    As noted above *intake* temp matters - it affects pump life and so on.
    Feb 2009
    Midwestern MN/Wi USA
    1,417
    74
    406
    Waterjet cutting creates quite a bit of heat actually. Comp must be done on large cuts. The plate will stretch.
