weird sinking weld beads
Page 1 of 2 12 LastLast
Results 1 to 20 of 37
    Nov 2016
    Michigan
    23
    5
    Question weird sinking weld beads
    Anyone ever seen weld beads like this?
    They are like sinking on the tube looks like icecream scoops.
    Mar 2013
    Cerritos, CA
    329
    111
    132
    Excessive heat, it’s just penetrating inside the tube.
  3. Likes B-Mathews liked this post
    Dec 2004
    uk
    12,618
    3563
    5682
    Yep excessive heat, reduce amperage or add more filler and move faster. If thats not the welders first ever weld, they need to either go back to weld school or lay of the drugs!
    Its impressive they managed to make welds that sunken though with out blowing holes, theres clearly some skill showing there even if its not good skills!
  5. Likes Monarchist liked this post
  6. #4
    Langley, B.C.
    1,334
    252
    754
    Quote Originally Posted by Lanso View Post
    Yup, you're just at the point where the weld is starting to blow out. Just a little more heat and instead of sagging welds you'll
    have holes. Turn your heat down and do some more practice...
  7. Likes digger doug liked this post
  8. #5
    Langley, B.C.
    1,334
    252
    754
    Quote Originally Posted by adama View Post
    You got in just before me--said the same thing I did with twice as many words. As to the degree of sag I agree about the talent (?). I think I'd be hard-
    pressed to run that hot without blowing a bunch of holes in the bead...
  9. #6
    Sep 2017
    Wisconsin
    192
    71
    Looks like they started out too hot (or slow! Look at the wide HAZ) and then backed down for the majority of the bead. Looks like a lack of tempo is also present; a laywire technique and a metronome or automatic pulse may help the welder develop a rhythm.
  10. #7
    Sep 2002
    gloucester ma
    1,831
    67
    1280
    the right most is fusion welded, no filler then they seemed to remember filler....
  11. #8
    Oct 2005
    10,354
    17406
    5409
    Next time, have the student use a helmet.....
  12. Likes PlasmaOnTheBrain liked this post
  13. #9
    Mar 2010
    Davidson NC USA
    1,345
    443
    772
    Only a rookie welder wears low quarter shoes while stick welding. Please don't ask how I know this. Regards, Clark
  14. Likes PlasmaOnTheBrain liked this post
  15. #10
    Nov 2010
    Tustin, CA
    235
    115
    48
    Quote Originally Posted by sealark37 View Post
    Except that's not stick, so it doesn't really matter. I weld in skate shoes and shorts all the time.
  16. #11
    Nov 2016
    Michigan
    23
    5
    The other side of the gusset was welded at a higher amperage and same amount of filler and was fine. When he flipped it over it started to sink so he turned the amps down more and more but it still sinks and just generally doesn't want to stick. It was cleaned and prepped perfectly too.
    Here is the other side
  17. #12
    Dec 2015
    Illinois
    138
    41
    82
    Quote Originally Posted by psandherr View Post
    Did he wait for it to cool before he started on the other side?
  18. Likes digger doug, sfriedberg liked this post
  19. #13
    Sep 2017
    Wisconsin
    192
    71
    That was my immediate thought as well...
  20. #14
    Nov 2007
    marysville ohio
    8,711
    2462
    5556
    Quote Originally Posted by Rick Finsta View Post
    That looks like a race car wishbone. If it is scrap it and get a welder who knows what he /she is doing, safety critical parts are not for amateurs. In my opinion the "good" side looks like crap also.
  21. #15
    Nov 2010
    Tustin, CA
    235
    115
    48
    Way too much undercut and not enough filler.
  22. #16
    Oct 2005
    10,354
    17406
    5409
    Quote Originally Posted by moonlight machine View Post
    And someone that can inspect for a faulty weld as well.....
  23. Likes adama liked this post
  24. #17
    Jul 2011
    Utah
    659
    1228
    232
    Root pass!
  25. Likes digger doug, PlasmaOnTheBrain liked this post
  26. #18
    Oct 2005
    10,354
    17406
    5409
    Blind leading the blind.....Pretty sad state of affairs of our
    educational system these days.
  27. #19
    Dec 2004
    uk
    12,618
    3563
    5682
    Yet anouther classic example of why people bring me stuff to weld!!! I may not be coded, the weld may or may not need x raying, but suck me that should look so damn beutiful, a nice lap weld joint like that is about as easy as it gets.
  28. #20
    Nov 2007
    marysville ohio
    8,711
    2462
    5556
    As bad as that is I can't imagine posting it for all the world to see. Looks like he has about 2 hours experience with TIG, maybe less than that!
  29. Likes digger doug liked this post
