had boss come by on job site once said taking too long to weld and making the welds too big on 4"sq tubing 1/4 thick.
had to say 1/4" fillet welds is ok if no joint gap but if tubing has a 3/16 gap i was making weld 1/4 bigger or 7/16"
and field welding over head and vertical up slows down considerably if you have bad joint fitup with big gaps.
no many weld calculators mention that. they are assuming perfect joint fitup or gaps
Yes a calculator would only be good for perfect fit up for sure. In this case everything will be perfect and articulated for flat
welds,
Notice
