Welding eyelets on 1045 chrome rod
Results 1 to 3 of 3
    Jan 2003
    572
    110
    179
    Default Welding eyelets on 1045 chrome rod
    Wondering what everybody recommends for filler when tig welding 1045 chrome rod to mild steel eyelets. This job is for a small hydraulic cylinders. I understand 1045 is prone to cracking without proper preheat. What would be best filler to reduce chances of this? Just regular old ER-70S2? Would 309 be any more crack resistant in this case?
    Will the preheat damage the chrome plating? It definitely discolors it. Will it be more likely to rust close to weld? Any other tips and tricks here?
    Aug 2011
    new plymouth id
    518
    41
    135
    on most of the new cylinders like prince and baileys that I have purchased, they are usually retracted and ends painted so the discoloration isn't seen. I have had to change out the eye and its maybe a 3/8 deep fillet weld on a 2" rod no sign of preheat the old timers I used to go bug, when they could still see always used 11018 1/8" rod so thats what I use
  3. Likes mmurray70 liked this post
    Nov 2019
    CANADA
    Ontario
    525
    780
    124
    regular er70s-2 will be more then adequate to hold it.
