GisMo
Hot Rolled
- Jul 29, 2004
- South East FL/NYC
I need to weld a gear to a shaft(yet to be made) I do not know the type of steel that the gears are made from. I do know the hardness is 64Rc. Pretty hard. I was mainly concerned with the weldability if the gear is carburized and also, the loss of the HT in the gear post weld. The welding is near the teeth. If so, I would/can get the shaft with the gear re-heat treated. Then that leads to knowing the gear composition and then using the same filler so the HT is consistent. I talked to the HT place here and recieve no help. If I cant find out what the gear material is, I was thinking just to use a 4130 shaft and filler and just weld and try to heat treat. The guy at the HT place said we can try it. I dont think I have time to get the gear chemically tested, but thats an option... what do you suggest?
