welding spring steel
Apr 4, 2007
Qld Australia
hi i used the search and couldnt find any thing
so is it possilbe to properly and strongly weld spring steel
the reason i ask is because i am lookin into making and adjustable anti roll bar for a car
and if you go to the following page there is a picture of what i want to do
http://www.hrpworld.com/index.cfm?form_pic_id=1432_1&action=product_picture&form_cat_id=217,212,363
so is it posssilbe and if so what method(welding and cooling procedure is to be used
all info would be great
cheers Brendan
Is the milled flat component rotateable? (I ask this as I see what looks like a bell crank or lever with linkage attached to it)
If so, it is the "spring" element , fits thru a socket that functions as a bearing and has no welding on it.
The "adjustment" in rate would vary as you rotated this element - more flat (presented normal to suspension travel) = less resistance in bending.
The "structure" (sockets, cross tube) would just be 4130 normalized tubing which has been welded on sucessfully for ages in the aircraft field.
John
thanks for all the help
can i down load a specs sheet for all the grades of steel (4130,4140 etc)
so john wat do you think would be the way to construct the spring element
cheers brendan
4140 prehard (I.E., low thirties on Rockwell C scale) round bar, lathe and mill work to suit, no welding. Before the industry dreamed up this term (prehard), we just called this stuff 4140 commercial heat treat.
6150 a little harder than above would be a better spring, but I do not expect you will come across any
Some of the aircraft supply houses (such as Aircraft Spruce in California USA) used to sell 6150 round bar, but you would need to take care of the heat treat required, and this is not a do it yourself process.
Any such machined spring element will need very nice finishes and no tool marks / sharp corners if you want it to live awhile. Busted parts of this fancy anti roll bar are not likely something you want :D
John
Shot peening the root radius of the spring (the rotatable tapered plate on each end would be the main area to watch for. this radius is important. Get the taper right as well I am guessing that it is profiled to give constant stress in bending thereby making best use of the material properties. Don't get overly fussy if the material is run within reasonable stress limits it will survive. similar to the springs on your car in other words good design will go a long way towards making this part live.
