This is what the laser shop sent me...
Page 1 of 3 123 LastLast
Results 1 to 20 of 43
    Apr 2019
    Georgia
    24
    25
    Default This is what the laser shop sent me...
    Sent some steel work out to a laser shop. Thought I'd get everyone's thoughts on what I got in from them. It's a smaller shop and I know one of the guys there really well. I didn't specify that they'd break the edge or finish the part. I just trusted my bud's shop to take care of me. They told me I'd have to tumble them some. I told them we have two tumblers so we can handle it, but I wasn't expecting to get something so rough. I've never had a fiber laser cut part come back looking anything like this. I've had some burr and dross, but this is pretty nasty. It's a 6kw laser and 1/4" steel. I'm thinking they don't have the thing set right.
    Mar 2017
    LATVIA
    768
    212
    447
    had something like this with an alloy steel sheet, composition similar to 4140, 2mm thick, it had some mill scale with rust preventative on it and the parts looked similar to yours, they were very apologetic about the result, they always supplied me with near perfect looking parts from either mild or stainless, regardless of thickness, from 1 to 25mm (mild steel)
    I cleaned up the next sheet before bringing it to them to be cut, degreased and lightly sanded the scale, and the result was much better, still wasn't near perfect as mild or stainless, but much better
    Jul 2006
    Hillsboro, New Hampshire
    12,494
    2856
    8685
    Those are terrible, unacceptable. You can't "tumble" that away. Even using a Timesaver, it could be hard on the belt.
    I'd either talk to your buddy, or chalk it up to experience and get them done elsewhere (with a guarantee of edge quality).
  4. Likes doug8cat, Strostkovy, Joe Miranda liked this post
    Jan 2014
    GA, USA
    26
    6
    Cutting 1/4" steel with nitrogen can do that if you don't have something set right. Which it appears they don't. It being HR will play into that some. We had issues cutting 1/4" with oxygen for some reason or the other, I swapped over to use nitrogen. Once everything got dialed in it cuts great. That said we try to use only HRPO cuts cleaner does leave a slight burr but nothing like this. Like Milland said thats going to be hard on a timesaver belt. Paint scraper and a hammer you can get under the burr and can pop off the burr. Sometimes.
    Oct 2005
    21,160
    On my oxy cnc table I get it like that sometimes, I keep a 4" wide masonry chisel
    handy.
    It has enough weight, you slide the slag "off", not the other direction.
    The 4" wide makes it easy to find the last bits still hanging.
    https://www.homedepot.com/p/Dasco-Pr...-100507480-_-N
  7. Likes DrHook, gbent, neilho, Toolmaker51 liked this post
  8. #6
    Apr 2005
    Brandon, MS
    878
    134
    201
    That's pretty bad indeed. 1/4" should be no problem for a 6 kw laser. Something is definitely "off".
    A frank conversation needs to be had and expectations need to be understood before the next order is placed. Otherwise, take your business elsewhere.
    My laser guy only has a 4 kw laser and there's not even a discernable burr even on 1/4" material. I'm not sure what type of laser he has though.
  9. Likes digger doug liked this post
  10. #7
    Oct 2008
    Central Ohio, USA
    2,045
    922
    595
    Wow, my Hypertherm 65 on my cheap plasma table looks better than that.
  11. Likes Joe Miranda liked this post
  12. #8
    Oct 2009
    Oregon
    5,905
    6401
    3273
    That is not acceptable.
    I get parts like every now and then. I happily have them redo them over and over until they are acceptable.
    I have noticed the uglier the parts are the more elaborate the wrapping/palletizing often is. Like the operators know and are trying to hide it.
    I have even gone as far as to note "Not to be cut from flaking rust pitted shit" on my PO's to one vendor.
  13. Likes Yan Wo, Winterfalke liked this post
  14. #9
    Feb 2014
    Cartersville, Ga
    427
    155
    257
    This is 1/4" from my vendor, if you need to see what you should be getting.
  15. Likes rcoope, michiganbuck, bryan_machine liked this post
  16. #10
    Feb 2016
    Washington
    265
    514
    148
    I agree with everybody else. That is horrendous. The 1/4" thick parts I've had laser cut are much closer to what Fish On posted.
  17. #11
    Mar 2005
    Kansas
    8,506
    585
    4250
    handy.
    I second doug's masonry chisel. Sharpen one sided like a wood chisel. Add a longer solid handle if more weight is needed. Works great for removing weld spatter as well.
    But no, you shouldn't have parts that look anything like that.
  18. #12
    Sep 2015
    Ohio
    1,683
    1123
    1746
    I would never send something that looked like that to a customer.
    Especially if I wanted to keep them as a customer.
  19. Likes Mike1974, Garwood, Joe Miranda liked this post
  20. #13
    Oct 2010
    Oregon
    5,639
    5441
    2123
    The last welding class I took at the local community college, that would have been totally unacceptable for hand-cutting with an oxy-acetylene torch. For a CNC fiber laser? No way!
  21. Likes Joe Miranda liked this post
  22. #14
    Feb 2011
    CANADA
    British Columbia
    170
    18
    41
    I've had the same results as Fish On - the laser shop we sub out to hates us because our orders are either really small, or the involve a million piercings, but the results are always similar to the photos Fish On posted. I also second Ohio Mike's comments about that being much worse than plasma, and I only have a Hyperther 45XP on the cheapest CNC table in the market.
    Here are some photos of why they hate us:
  23. #15
    Nov 2014
    Florida
    6,154
    2439
    3060
    Quote Originally Posted by Booze Daily View Post
    Ya!! How could anyone in good conscious send that out and expect to be paid?
    edit: even as 'just an employee" I would be embarassed...
  24. #16
    Apr 2019
    Georgia
    24
    25
    Thanks for the replies. I've been pretty straightforward with the shop that this batch of parts is no acceptable at all. The owner asserted that he thought I was trying to save money on some parts and his understanding was that these parts would be acceptable. He has taken strides to improve the quality of the cut. He still seems to think these parts were okay. I sent him the link to this post tp see if it changes his mind.
  25. #17
    Aug 2007
    Idaho
    2,375
    988
    1237
    We were buying mirror glass from a big waterjet shop in sacramento ca for 10 years with a less than 1% rejection rate, we just tossed them and never said anything, about 3 years ago all of the sudden we had a 50% rejection rate, scratched glass, chipped edges, poor packaging, after three batches we decided it would be cheaper to buy a protomax waterjet. The quality of work done out of house has become more trouble than it is worth. I have to think this will affect their bottom line but folks are being forced to hire better than nothing employees in many sectors but having the owner think those are acceptable is a whole nother thing all together. There may be a protomax in your future too.
  26. Likes bryan_machine liked this post
  27. #18
    Oct 2017
    1,242
    379
    425
    We state the part quantities are +-5% or whatever so that we can nest extra if they fit well or throw away ones that turn out bad.
    We often include ones that need work for free, because why not. It doesn't cut into our margins and the customers like it.
    But any part that bad would just be tossed into the scrap bin before a customer ever had a chance to see it.
  28. Likes Steven-Canada, bryan_machine liked this post
  29. #19
    Sep 2010
    Vancouver Canada
    1,029
    791
    409
    I spent a lovely week surfing in in Tofino BC last summer. Tofino accommodations are challenging and everyone has stories about deals they've had, good places and bad places etc. Early one mooring we saw a guy who was actually sleeping on the beach but inside his surf board bag, one of those padded ones with the sliver outside so they don't overheat in the sun. But they're always damp inside and at risk of mildew. So this immediately set a new low standard of Tofino accommodations for all others to be compared to, "well I was in a three person tent with four guys from Quebec and it was raining but at least I wasn't sleeping in my board bag!". Anyway, thanks to this thread we have now seen the laser cutting equivalent of sleeping in your board bag.
  30. Likes sfriedberg, Garwood liked this post
  31. #20
    Dec 2012
    Se Ma USA
    2,101
    172
    1122
    I have a measly 1000 watt fiber laser. I also have a scrap dumpster for stuff like that. Talk to operator or walk.
