what is the output on a Walter Surfox power supply?
Likes Likes:  0
Results 1 to 3 of 3
    Jun 2016
    New York
    1,456
    793
    618
    Default what is the output on a Walter Surfox power supply?
    Anybody familiar with the output of a Walter Surfox stainless weld cleaner? what is the voltage/waveform/current? how about other brands of cleaners?
    I've seen other brands that have a tiny cheap looking power supply, the walter is considerably more substantial, but also substantially expensive!
    Aug 2010
    Minnesota
    1,984
    150
    1464
    Hmmm... lets put two and two together on that, bigger power unit, more power with a better duty cycle.
    SURFOX MINI™ – Walter Surface Technologies
    SURFOX™ 305 – Walter Surface Technologies
    The smaller two are 15a max and the big boy is 30a... AC/DC for cleaning or etching.
    Mar 2004
    Edison Washington USA
    10,321
    964
    5322
    I have one of the rinky dink (but still expensive) "battery charger style"
    weld cleaners- mine puts out 40 volts, about 10amps. It will work for cleaning discoloration off of welds. It will not do anything to forged stainless, which is dark gray all over. Its good for jobsite work, where we just need to get rid of the blue.
    The Walters are better, I am sure- but, as you mention, German Pricing aint cheap.
    If I was seriously considering a Walter, I would bug a salesman until he brought one to my shop and demonstrated it. For that kind of money, I want to see it work. Walter has outside salesmen, who service big accounts. I have talked to them a few times over the last 25 years or so- they are usually pretty knowledgable, and, given that to them, a decent sized account is measured in tens of thousands of dollars a month in sales, they are unlikely to bug you later- its more about you bugging them, til they actually show up with a demo model.
    I have found there is no substitute for amps, and heated acid. I send all my actual electropolishing out to some guys who have a hot-tub sized tank of 100 degree phosphoric, and a 1000 amp 100 volt power supply.
    chromium oxide is tough stuff.
