White Cast Iron welding
Likes Likes:  0
Results 1 to 12 of 12
    Dec 2006
    NJ
    1,858
    283
    445
    Default White Cast Iron welding
    Ever weld White Cast? I've been told you cant. Anybody suggestions on rods selection?
    Jay
    www.CandLMachine.com
    Jul 2004
    Houston, TX USA
    31,957
    As a place to start, Moldenke in Principles of Iron Founding (1917) gives the composition as:
    Silicon: below 0.75%
    Manganese: above 0.20%
    Sulphur: below 0.25%
    Phosphorus: below 0.75%
    Total carbon: above 2.50%
    He notes there is no graphitic carbon due to low silicon. (that's why its white!)
    I.E., you are trying to weld something that is at least 2.50% carbon, and possibly as high as 3.75% carbon - all chemically combined.
    John Oder
    Dec 2006
    NJ
    1,858
    283
    445
    Jan 2008
    Merced, Calif
    1,046
    1257
    221
    Default Cast welding
    Try going to locknstitch.com and see what they recommend.
    Nov 2004
    Birmingham, AL
    13,335
    6617
    2631
    I want to watch somebody drill white iron for a lockstitch repair. Last time I had to drill white iron, it was just a layer where some past bonehead had burnt a nickel rod into my lathe apron casting to repair a crack (which didn't work) with no preheat or proper cooling. This was maybe a 1/8" thick zone, which was like drilling volcanic basalt. I burnt up three 1/4" drill bits getting through that little area, after which, it was back to typical soft sweet cast iron. I really doubt you could lockstitch for this reason alone, unless you could get the part in a mill and use a carbide endmill or solid carbide drill(s).
    I can't imagine how you could get a good weld in white iron, but I'm game to learn something.
    Jan 2005
    Salem, Ohio
    4,103
    47
    92
    Cool
    I would like to try welding some for something to do. I know i push Crown Alloys 255 rod but its the only Crown cast iron rod i can find the words for "ALL Cast Iron" so it may work, just my thought...Bob
    http://www.crownalloys.com/page10.pdf
    Sep 2005
    il.
    6,912
    49
    1428
    i give up
    what is "white cast"
    Jan 2005
    Salem, Ohio
    4,103
    47
    92
    Nov 2004
    Birmingham, AL
    13,335
    6617
    2631
    wippin' boy, the surface of the bed ways on your L&S are white iron.
    Jul 2004
    Houston, TX USA
    31,957
    Its got over 2 1/2% silicon - wonder how it gets to be white.
    At least white all the way through.
    John Oder
  11. #11
    Dec 2006
    NJ
    1,858
    283
    445
    Update so far,
    I purchased from Muggyweld.com and I have sample rods coming from 2 other sources. One also is sending brassing rod. I'll upadate and provide pics when the pieces come in.
    Jay
  12. #12
    Sep 2005
    il.
    6,912
    49
    1428
    then my answer to the original question would have to be braze it
