Superbowl
Hot Rolled
- Feb 12, 2020
Hi Guys,
I picked up a Lincoln Weld Pak 180 HD (Home Depot model) in a package deal on a bunch of other equipment and it is not working right. I am thinking the problem may relate to the voltage setting knob. This knob's label has five settings labeled A-E that span 180 degrees around the knob. The knob moves with clicks and positive stops.This seems to me to imply that this knob should turn only 180 degrees with five positive stop clicks. However my knob turns about 500 degrees with 14 click/stops.
If you have one of these welders, does your voltage knob make only the five clicks and only turn 180 degrees?
