Who makes a good layout protractor?
Results 1 to 15 of 15
    Sep 2010
    Oklahoma City, OK
    4,683
    804
    1924
    Default Who makes a good layout protractor?
    I've been using a Starrett, but I'd like something less delicate for use around the welders and torches. Does anyone make something similar that wouldn't make my eyes water if I struck an arc on it by accident?
    A little thicker blade wouldn't hurt as it's often used as a guide for the plasma torch. Bonus points if it's aluminum.
    I've looked at Empire, trig jig, and trick tools.
    Thanks!
    Virginia
    28,788
    7561
    8936
    Quote Originally Posted by Cole2534 View Post
    Thanks!
    Strike an arc on a Starrett?
    If/as/when you choose to put a layout tool in harm's way like that?
    Time for some jigs and fixtures 101 tasking.
    Go lay-hands on some aluminium you like in the thickness you like, and make up a batch of several "expendables" to suit the shop-floor need. Might want to consider FR4 or carbon fiber so it ain't as easy to strike an arc on it to begin with?
    No need of a dividing / ruling "engine". OK to cheat and use store-bought "degree wheels" or cut-ups from them as attached parts.
    Even easier, yah cut the same angles often. Make fixed, "dedicated" ones, prominently mark - even colour-code those - and reduce risk of error as a beneficial byproduct.
    Jun 2012
    Michigan
    10,418
    3549
    3715
  4. Likes Kiwi2wheels liked this post
    Mar 2005
    Kansas
    7,697
    459
    3618
    Have you looked at Flange Wizard's stuff?
    Oct 2005
    16,528
    Design something and have the parts laser cut out.
    Work with the laser shop, they can do etching as well for the graduations.
    Sep 2010
    Oklahoma City, OK
    4,683
    804
    1924
    Because, as I said in the directly following sentence, it gets used as a torch guide.
    Oct 2005
    16,528
    Make the arm from 8020 or something, that would allow stops and other features.
  9. #8
    Sep 2010
    Oklahoma City, OK
    4,683
    804
    1924
    Quote Originally Posted by gbent View Post
    Close but no cigar.
  10. #9
    Sep 2010
    Oklahoma City, OK
    4,683
    804
    1924
    I was about halfway down this route already, but stopped and asked.
    Thanks guys!
  11. #10
    Virginia
    28,788
    7561
    8936
    "We've always done it that way" doesn't make it the best, let alone most economically efficient, way to guide a torch.
    But your rationalization for doing it is probably even LESS likely to depart the line than the Starrett protractor is!
  12. #11
    Oct 2005
    16,528
    Yup, I won't even touch "the best protractor" because the best one in your shop is the ones the people in your shop need & want.
    Make some mockups get some input.
    and remember that in your shop, this tool is a consumable.
    But it's o.k., bang these things out, and always have some spares on hand (maybe the aluminum arm will need more replacing)
  13. #12
    Mar 2005
    Kansas
    7,697
    459
    3618
    Torch as in O/A or plasma? If you are using an O/A, can you switch to plasma? Its cheaper, and with a Hypertherm with a drag tip, a piece of sheared sheet metal makes a dandy template. When you ding both edges, throw it out and get another. For one or a couple of usages, a welders wrap a round cut to shape will work fine. I could easily see a couple of pieces riveted together and set with your Starrett, away from the fire.
  14. #13
    Jan 2019
    Tennessee
    553
    176
    146
    bridge city tools 6 in one? kind of pricey, but has nice features like the stepped edge.
  15. #14
    Sep 2010
    Oklahoma City, OK
    4,683
    804
    1924
    That's what I'm using! Mainly to miter joints since my bandsaw is square cut only.
  16. #15
    Dec 2003
    suburbs of Ann Arbor, MI, USA
    13,094
    437
    1059
    A thought would be to make a friction gage (wing nut, etc) you set with the Starrett.
    Then go at it using the shop made gage.
