The most common cause is that the seat where your cutting tip mounts is scarred and causing a leak. The torch sits there and goes pop, pop pop, slowly. I see this all the time on CNC cutting machines. Smart shops store their tips covered to keep general shop crud off of them. Less quality controlled shops usually have a rack near the cutting machine with holes drilled in them. They stick the tips in them with the seats facing up, and you see evidence of dust, dirt, and grit settling on these imporant seal surfaces. Next some monkey with a wrench sticks the dirty tip in the torch, it doesn't seal, so they carnk the tip nut even tighter and score the seating surface. Eventually it gets so bad I get a call because the machine constantly pops out trying to pierce holes.
The best solution is to ream the torch seats to fix them, and replace all the torch tips and keep them clean. Otherwise, the first time a dirty tip gets installed and cranked down, the seat is buggered again, and in short order all the torches on the machine have the same problem.
It's one fo the reasons I love Smith tips. They have a soft seat and no wrenches are needed other than for the firs use of the tip.
