Wiring an Amada RG-50 press brake, question about the stinger leg
Results 1 to 5 of 5
    Aug 2010
    Santa Cruz, CA USA
    182
    299
    67
    Default Wiring an Amada RG-50 press brake, question about the stinger leg
    Just got a new to me 1984 Amada RG-50, I have the manuals but can't find instructions for wiring it up with a stinger leg (which I have). My Geka iron work had clear instructions for which terminal you should have a stinger leg wired to, but I can't find that info on the Amada. Worried that the stinger on the wrong terminal will fry the controller. Does anyone out there have direct experience with this on Amada machines? Any help at all would be greatly appreciated.
    May 2011
    New Jersey
    656
    14
    226
    Stinger leg, you mean the high leg on a 230v set up? If that's true, it's simple. Just connect it to the 1 leg that does not connect to the transformer.
  3. Likes gary-sc liked this post
    Dec 2003
    suburbs of Ann Arbor, MI, USA
    13,164
    451
    1082
    Does it use a neutral in the cord-set?
    I would expect 240vac/480vac on all combinations of phase-to-phase.
    Seems odd that it would be wired with a neutral, because then it couldn't be used on 240/480vac delta with no neutral wire.
  5. Likes gary-sc liked this post
  6. #4
    Aug 2010
    Santa Cruz, CA USA
    182
    299
    67
    Thank you both, no neutral on our 3 phase, the Amada book says it will run with or without one.
    Bondo, thank you very much that's exactly what I needed to know. I thought it might be the transformer that couldn't take the high leg (I grew up calling them stingers.)
  7. #5
    Mar 2005
    Kansas
    7,981
    492
    3815
    On a properly wired machine it makes no difference where the high leg is placed, as all power is leg to leg. There is no way to find the high leg when checking leg to leg. High leg placement matters if a neutral wire is required, which means there is power from leg to ground.
