I have never seen a scroll machined, nor have I any knowledge of how it was done. It is an interesting subject which has had me thinking about it at odd moments over the years- usaully when I use a scroll chuck or clean/main tain one .Thinking it over, I wonder if the following setup might work:
-If a shop had to make one or two scrolls, they could use an adaptation of the setup for milling helical flutes or a worm on a horiztonal milling machine. In this method, the table feed and the dividing head are connected by gearing so that the table advances for the lead of the helix, while the gearing from the table feed screw turns the divinding head. For milling a scroll, the same concept should work. A very similar setup would be used, only the milling machine would need to have a vertical spindle, and a rotary table would be used to mount/revolve the scroll blank. The "X" Axis feed screw would be geared to a rotary table on a vertical mill, table's worm shaft and the "X" axis feedscrew. As the "X" axis feedscrew turned, it would advance the scroll by the lead of the "thread", while causing the rotary table to revolve. An set of end mill cutters ground for roughing and finishing the scroll "thread" would be likely needed. Cinncinnati and Brown & Sharpe milling machines had the capabilities for this sort of gearing to connect a dividing head and "X" axis feedscrew for helical milling.
-If a shop were in production of scrolls, as for the manufacture of chucks, I would imagine they would have a dedicated milling machine setup for the purpose. Cutting a scroll in a lathe would require numerous passes with a single point tool. If a lathe were wanted for the porduction of scrolls, a "tee bed" lathe might have been ordered. A "tee bed" lathe was built for specialized work, usually done on a faceplate. The bed laid at 90 degrees to the spindle, and it had a carriage, cross-slide & compound as a regular engine lathe would. With a lead screw geared off the spindle, but the bed laid at 90 degrees, a "tee bed" lathe could have been used for making scrolls.
Vertical turret Lathes and Vertical Boring Mills pretty well did away with the need for tee bed lathes.
-FWIW: At Brooklyn Technical HS, there was a separate little toolroom type of shop which was off limits to most students. It was in the charge of a cantankerous teacher, who was in truth, a fine toolmaker. He had the job of making jigs and fixtures, making instruments and test fixtures, and repairing all manner of finer stuff. This particular guy had his little inner sanctum which he only let a favored few students into. I was not part of the favored few, so did not get into the inner sanctum. On towards my senior year, that oldtimer softened up slightly towards me, and let me take a look at his private toolroom. Amongst other machine tools, there was a Rivett bench lathe that "looked old". It was like no other bench lathe I had ever seen. It looked to have a bedway on the vertical front face of the bed aswell as on the top of the bed, and had loose change gears. The oldtimer explained it was a special lathe which had the ability to cut scroll threads. I never saw it set up for the purpose.
OTOH, we had the good fortune to have another ex toolmaker as our regular shop teacher in our junior and senior years. This teacher was named Ivar Alskog. Mr. Almskog was one of the finest men I have ever known, any way you took him. He was a fine toolmaker who had returned to his alma mater to teach after years in industry. Mr. Almskog took a genuine interest in us kids and taught us shopwork as well as something of life as we approached our adult years. By today's standards, I suppose Mr. Almskog would be called on the carpet. He was an upright man who kept a worn copy of the Machinery's Handbook and an equally worn Bible on his desk. He had the patience of a saint with us kids. From the way he worked, and the fact he never seemed stumped, you had the feeling he could probably make anything if you handed him an idea or sketch and turned him loose in a machine shop. The machine shop classroom we were in was equipped with geared head Hendey engine lathes, probably about 14" x 50" between centers, LOO tapered spindles. These lathes were driven off the overhead lineshafts. SOme of the shops at 'Tech had been refitted with(then) brand-new LeBlond Regal engine lathes. As kids in the Mechanical Course, some of us looked at the older Hendeys and thought we were getting the short end of the stick. Mr. Almskog heard the mumblings and explained to us that the Hendey lathes were some of the finest engine lathes ever built. He said he had done all manner of off the wall jobs on a Hendey, including cutting multiple lead threads and gauge work. He showed us a relieving attachment and gearing for the Hendey engine lathes, though we did not use it. I had gotten to talking to Mr. Almskog about the Hendey lathes and he showed me an old Hendey manual with a picture of Henry Hendey in the front flyleaf. Mr. Almskog told me that Hendey used to build lathes to order for production work, as well as making up all manner of attachments for their lathes to special order.
It would not surprise me if Hendey offered a train of gearing to connect the cross slide to the spindle in the manner of a lead screw for threading of scrolls. With the type of gearing and drive shafting they already had in production for their relieving attachments, it would not be too much of a stretch of simply provide a spiral or bevel drive to the cross feed screw.
The methods for machining a scroll produce a scroll out of a soft steel blank. For use in a chuck or similar, a scroll is usually hardened and ground. Grinding down into a "face" thread or continuous narrow groove has got to be an equally interesting proposition. I wonder if the hardened scrolls were then setup on the same type of milling machine/rotary table, only with a high speed grinding spindle mounted on it.
