300 HP milling cut
Page 1 of 2 12 LastLast
Results 1 to 20 of 29
    May 2003
    Iowa
    10,490
    3616
    4281
    Post
    Watch the video, 24" dia cutter, 18" wide, .75" DOC, etc.
    http://www.mmsonline.com/articles/0105ex1.html
    JR
    Sep 2003
    Roscoe, Illinois
    1,515
    51
    Post
    I ran this machine a few times before Ingersoll changed hands. The company that bought it is a tool steel foundry in Pa. Our test ingots were either d-2 or 4140. Cutting at 300 hp the inserts didn't last very long. Chips came off orange and if they stayed on the table under the rail, the oil in the return trough could catch fire. Finally Ingersoll had to change the type of oil used for the hydrostatic ways.
    Cat 60 taper tool and a right angle attachment to go along.
    Feb 2004
    peekskill, NY
    25,526
    5277
    Post
    Nice. Basically porn for metalworkers. [img]smile.gif[/img]
    Watch carefully at the end of the cut, and
    you can see the broom being used to clear the
    chips ignite a couple of times, on the left
    hand side of the cutter, behind it.
    Jim
    Dec 2002
    Pacific NW
    5,171
    8
    884
    Post
    I always enjoy watching Ingersoll demo their inserts at trade shows. Nothing like in the video, but they get your attention.
    They take blocks of steel and do operations with their various insert drills and cutters throwing red hot chips and sparks that us mere mortals can only dream of. Of course, the fact that they're doing the cutting on a big hunking 50 taper Mori might have something to do with it.
    Mar 2004
    Granada Hills, CA
    498
    Post
    I want one.......will that fit on a bridgeport?
    Nick
    Jul 2002
    northfield ct usa
    606
    Post
    wow and i thought i was realy removing metal when i had that 10 inch dia carbide cutter mounted on the spindle of my horizontal mill, but the way my garage is i had a great fear of fire from a hot chip in the clutter so i backed off on the cuts after a few close calls. and then later i managed to have a hunk of slag wipe out a whole bunch of the odd, ground in place, carbide inserts so i dont have it anymore, but i had only paid $1.50 for it it did alot of cutting before that on my 5 hp cincinatti. that cutter actualy would make the machine bog down a little, something no cutter i ever had in the horizontal spindle did, heck the time i got stupid with a large hole saw and twisted the tangs off a morse taper holer the machine didnt even change tone just all the sudden the hole saw stopped turning!
    Nov 2002
    3,331
    1980
    849
    Post
    HOLY MOLY BATMAN!
    BANG, ZONK , WHAP
    I want one!
    DOug
    Jul 2004
    Vicksburg, MS
    4,931
    30
    259
    Post
    Nice. Never mind the machine, the weight in chips they cut off probably costs more than I make in a month. I loved the shot of the smoldering chips. I didn't see any coolant there, I am assuming that was done dry? Was that just for the demo? In production why would they not use a flood collant system of biblical size?
    Feb 2003
    So. Cal. 33.61N 117.66W
    389
    Post
    Let's see, what size VFD would I need to run one of these? Now, assuming I'll need to downrate the VFD to run off single phase...what size cables will I need to run into my garage?
    Dec 2000
    Bremerton WA USA
    10,710
    41
    4375
    Post
    300 lb of chips a minute? Here's where a big apprentice with 24" biceps and a size 5 hat comes in handy with his shovel. On this machine a chip converyor is a must.
    When I was 22 years old apprentice and my chest was still above my belt it was all I could do to keep ahead of a 50 HP machine working full time shoveling and hauling chips. We had 24" concrete carts we hauled them in and when full of 6's and 9's the tires woud squash almost flat and the heat would blister the paint.
    This Ingersol must have had a real ship conveyor something like the track drive for a tank.
    Scalped ingots and consinuous casting are reasons fine steels are so expensive. It costs a bunch of money to full anneal a 20 ton ingot, machine off 10% of the weight to clean metal, then re-heat it and roll it to merchant stock. But the metal is certianly clean and fine. It's been many years since I've run into included scale or pipes machining plate or bar stock.
    I recall Jack Neimi once machined a big flat steel plate on a floor mill cutting many pockets in it for sonar transducers. The material was behaving strangely (it didn't bong or clang normally when suspended from the crane and knocked with the plate clap wrench) but Jack went on anyway to discover a large blister in the metal like a de-lamination in cheap plywood. It was lined with scale and later exploration revealed it to be about 3 ft x 4 ft shaped like West Virginia.
    Apparently the ingot from which the plate was rolled was cropped too tall and it included a hunk of the "pipe" - that portion in the top center that feeds the lower part of the ingot with liquid metal as it solidifies from outside in after pouring.
    This episode caused every piece of plate from that manufacturer in the system to be inspected. Huge plate fiasco of 1968.
  11. #11
    Jul 2003
    Linwood, Ma USA, the center of the known universe
    274
    Post
    At my real job we have two Ingersoll horizontal bed millers 100 hp spindles. Typical cut with 16 inch cutter was 750" deep 16 ipm 12" wide, rpm about 90. Facing and matching ends on die blocks that weighed anywhere from 1 to 100 tons. Chips would fall down into a conveyor that was usually filled with oil and we would have several fires a day. Worse part was that the operators platform was directly above the conveyor. After facing and matching we would cut the shank which is 2" deep and 8" wide, using a 7" cutter with inserts that are 2" long (Greenleaf). First cut is 1.900" deep about 4 to 6 ipm. Chips so hot you could almost see through them.
    I hated that job because all that cutting was done without coolant. My employer is not too smart about coolant, they would prefer not to use it, $$$$. The job was so dirty with all kinds of stuff floating around in the air, due to the heat of the cut, you had to wear a filter mask to run the job, it sucked to say the least. In that video they are not using coolant either but that was probably for clarity during the taping of said video, I hope.
  12. #12
    Sep 2003
    Roscoe, Illinois
    1,515
    51
    Post
    There is no coolant on this machine. The inserts are hot enough that if they were hit with coolant they would shatter. The cuts were heavy enough that you really couldn't get enough fluid to do any good. Removing chips meant pushing them off the table into large holes in the floor next to the columns. The conveyors were 4 feet wide chains that lifted chips directly up into rail cars for return to the furnaces at the other end of the facility. Chips came off about six inches long curls. It was fun to run for a little while, then it was just like any job shop- make chips, move the part, set up another one make more chips. Ingots were held on the table by magnets and side crowders.
  13. #13
    Jan 2005
    Roseville, CA
    3,857
    26
    19
    Post
    WOW - Watched the video. What can I say. Brute American horsepower at work.
  14. #14
    Nov 2002
    3,331
    1980
    849
    Reviving a long dead (but oh so worth it) post:
    Unfortunately the link is dead.
    Does anybody have another link to this vid?
    I love watching it, and showing it to the unbelievers.
    Doug.
  15. #15
    Mar 2005
    near Rockhampton, Queensland, Australia
    5,559
    443
    2087
    Quote Originally Posted by doug925 View Post
    Doug.
    I have it saved on my hard drive somewhere... But it is on youtube I think...
  16. #16
    Sep 2006
    Lincoln, NE
    340
    7
    can't seem to find that, and I'd really like to see it.
    anybody got a link ?
  17. #17
    Dec 2009
    Louisiana
    500
    188
    287
    In for link
  18. #18
    Sep 2007
    Washington
    5,439
    227
    1705
  19. #19
    Aug 2007
    Wisconsin
    2,083
    1118
    947
    Here is another question-Whiuch is faster, milling plate on a beast of a machine like this or grinding it on a high horsepower grinder?? Our largest grinder now is 250 h.p. and my new one will be 300 or 350.
    With the grinder I put the plate on the table, turn the magnet on and start grinding. At the end of the cycle wash the table down and my filtration system does all the work.
    On a mill like this, unless you have it set up with magnets, there is alot of fixture work top do. Then after every part start shoveling the chips you did not get as the machine was running.
    I see alot of spindle downtime here.
    No doubt this machine is pretty darn amazing.
  20. #20
    Feb 2008
    lone jack mo
    376
    18
    My thanks to Finegrain!
    I did not see it on you tube on my search.
    Thanks for the link!
