batterzazu
- Sep 6, 2006
- Otsego Minnesota
My X axis readout has always went blank every once in awhile, today I went to use mill and the dang think keeps going blank. I took off the ends and squirted alcohol on the scale and wiped with a Q-tip and still have the same problem. So I switched the X and Y axis to see if the problem is in the scale or the readout, the problem is for sure in the scale. The mill is in my garage and is only heated when needed to day the high temp outside was 9 degrees above 0 I do not know if temperature is a factor here but I thought I would add that piece of info. I do have a swivel base on my mill so I guess i could just turn my work 90 degrees and use the Y axis readout for everything but I'll try the great brains here for help.
Thank You
Thank You
