Ball Bearing Comparison
Page 1 of 2 12 LastLast
Results 1 to 20 of 27
    Dec 2005
    Durham, NC
    238
    Post
    How would you compare the quality/durability of name brand metric ball bearings such as SKF, Fafnir, NTN, etc. with the same equivalent sizes/part numbers in Chinese made metric ball bearings.
    Just because it is made in China doesn't always mean that it is crap. Take things such as SCAT cranshafts and rods. The raw forgings come out of china and then are finish machined here in the US and they are considered top quality engine components for racing.
    So how do the chinese ball bearings compare?
    Roger
    Dec 2003
    suburbs of Ann Arbor, MI, USA
    13,038
    423
    1016
    Post
    I think if it has a recognizeable name brand its probably OK, those people have the resources and incentive to validate the claimed B10 life on their bearings and surely benchmark themselves against their competitors.
    MRC would be a little suspect in my book, I've seen their bearings die quite a bit sooner than I would have expected.
    Dec 2006
    NW Ohio, USA
    291
    29
    Post
    We have cold formers making millions of parts per year and as a test we put several different manufacturers ball bearings in transfer housings on 4 machines. SKF was best, Fafnir the worst. Ended up redesigning the gears to use Timken tapered roller bearings instead and have yet to have a failure.
  4. Likes Bill Widmer liked this post
    Feb 2007
    irl.
    172
    Post
    Not all bearing work in ideal conditions and irrespective of maker if bearings work in damp conditions on things like mowers in sports fields, golf courses on low speed application they are fine.I have broken these open and compared size for size with skf, fag etc. and found they measure up exactly. The problem I have seen with them is that they dont carry a brand name on most of them and if you get good results with them, another consignment can be hit or miss as the traceability is ? At a small fraction of the cost of the top quality product they certainly are value for money where the application will suit. I would be slow to use them in the middle of an expensive machine.In todays world of global manufacturing plants you are never sure where any bearing is made and a lot of badge engineering goes on. Cast your mind back 30-40 years - who wanted toyota, mitutoyo, etc.[CHEAP IMPORTS FROM JAPAN- TODAY MARKET LEADERS]
    Richie
    Apr 2002
    Tatlor Mi
    136
    158
    5
    Post
    iceman
    what make of coldformers and transfer types?
    Dec 2006
    NW Ohio, USA
    291
    29
    Post
    Those were on National 750-5 & 6 dies running 125 & 90 ppm with modified universal transfers.
    Jan 2002
    Wisconsin
    1,314
    26
    Post
    Well You may not think they have crap bearings, but my buddy asked me to help him repack the bearings on his boat trailer since it goes in water and was squeeking.
    He bought new bearings (from china) and came over. They did not fit..why you ask ?
    The corners were never ground and had square edges on the bore and OD.. talk about worse than crap.. they were.
    Rich
  9. #8
    Apr 2005
    Benton, IL USA
    4,567
    7
    47
    Post
    If the only marking on the bearing shell is CHINA, no numbers or letters, it is always crap.
    FAG-KBC are decent bearings that are often the 'house brand'. KBC is the former Korea Bearing Company, now produced by FAG Hanwha Bearings Corp.
    Barry Milton
  10. #9
    May 2004
    Chilliwack B.C. Canada
    700
    Post
    I thought this topic was going to be about ABEC ratings. Have you seen the spindle quality bearings on roller blades? I wonder how trustworthy the ratings are for import bearings-
    I had some motor bearings replaced by a shop once- they lasted about a week before they were as bad as the originals, which lasted several years.
    Re Barrys comments- I'm going to be looking for all the proper numbers on the bearings before I buy. If nothing else I'll have the comfort of knowing I bought poop instead of crap. (poop is one step up from crap [img]smile.gif[/img] )
  11. #10
    Jul 2005
    North(very) West(very) Ohio...near exit 13 on OH turnpike
    3,680
    181
    Post
    Give it a few years, chinese bearings will be too radioactive to import
  12. #11
    Sep 2002
    New Milford, CT
    565
    Post
    You have to distinquish between Chinese brands and Chinese made name brand bearings. The major players, INA/FAG, SKF and Timken all manufacture in China and have top notch quality control, so those bearings should be the same quality as those made here and in Europe. Timken is the only major I know of that imports Chinese bearings, so if you see an SKF or FAG with Chinese markings on it, be suspect. It would also be a good idea to buy from a reputable supplier since there are alot of counterfeit bearings coming out of Asia. FAG and SKF just confiscated 40 tons of bearings from a German distributor.
    The problem with Chinese bearings are the quality of the steel, tolerances and just plain poor workmanship. A high purity steel is vital for long life in a bearing and the Chinese steel mills cannot supply enough to the major players, so it is unlikely the Chinese brands are using anything of much quality. The surface finish also has a very large impact and they fall short there too. You can expect a life of less then 10% of the quality brands.
    If these are being used in something that will see little use, then you might be OK with the Chinese bearings, but if your companies reputation is on the line, or the failure would cause expensive repairs, then I don't think it would be worth taking the chance.
  13. #12
    Jun 2001
    St Louis
    18,041
    1893
    3046
    Post
    Chinese?
    I bought some bearings a while back and they were from Turkey...... Name brand, too, I forget who.
  14. #13
    Sep 2017
    PAKISTAN
    Thumbs up All Chinese bearings are not crap
    I believe what happened to your buddy was really not good, But all suppliers does not supply this kind of crap and if something happened like that they would have insured it that is something goes wrong you can claim and you can have the same shipment back or your money . . .
    I can suggest you may visit this website regarding the bearings
    http://www.wuxilotton.com/
  15. #14
    May 2013
    india
    Hi Roger,
    I think Chinese Bearings are different form such as this types ball bearings brands name like SKF, Fafnir, and NTN.
    If you want to get some information on this brands, so i am suggesting you this website which is providing bearing rollers, needle rollers and cylindrical rollers.
    Here is the reference website : Bearing Roller Manufacturers & Exporters India | SKP Bearings
  16. #15
    Sep 2004
    RSA
    1,101
    394
    279
    Quote Originally Posted by rhpope View Post
    Roger
    I use/replace a fair amount of bearings - maybe 40-60/months. I usually buy KML brand - Chinese. 1/4 to 1/2 price SKF/FAG. They are perfectly fine. I find them very consistent, seals are good and I could not tell the difference between those and SKF. I find FAG a bit of a disappointment - a bit more inconsistency than I would wish for particularly in C2. But you won't see that in an electric motor. I had very bad experience with NTN and I avoid those. For applications where the bearings are really stressed I use only NACHI with RS1 seals.
  17. #16
    May 2009
    Canandaigua, NY, USA
    2,890
    141
    1291
    Quote Originally Posted by JST View Post
    Chinese?
    I put Turkish bearings in a grinder spindle and no complaints at all. Quality product, ORS I think.
  18. #17
    Mar 2017
    CHINA
    1,576
    1133
    Quote Originally Posted by MBensema View Post
    Heat treat also. Have a friend who imports cheap junk bearings for a cheap junk job, but out of every batch he'll take a few and hit them with a hammer. If they shatter he sends that batch back.
  19. #18
    May 2017
    FINLAND
    1,787
    496
    816
    Steel quality (inclusions) is probably the biggest difference and thus lifetime.
    Even brand name manufacturers have improved the steel quality by heaps in the last 30 years or so.
  20. #19
    Sep 2004
    RSA
    1,101
    394
    279
    Quote Originally Posted by SeaMoss View Post
    WHY ??? Are they not supposed to shatter ????
  21. #20
    Sep 2004
    RSA
    1,101
    394
    279
    Quote Originally Posted by MattiJ View Post
    Some would agree, some would disagree. Some would say steels are cleaners, some would say the "chemistry" has changed and they don't take punishment as well. .
