8ntsane
- Sep 7, 2004
- Barrie,Ontario, Canada
Hello all
I have a problem keeping my Lathe level in my shop. My shop is located in front of a major hi-way here in Toronto, and a few years back they added a few more lanes that come closer to the building I,m in. The foor in my shop has these big cracks all over the place, and I can,t keep the machine level. I can,t even keep my two car hoists level for anymore than about a month at a time.
I really need to find a way to stop this problem.
I have 12x37 chi-won Lathe,and need suggestions on what you guys would do in this situation, sort of moving of coarse. I was thinking maybe mount the lathe on a 1-inch thick steele plate, with some type of machine mounts under that. I don,t really know whats the proper method to remody this problem.
I have seen lathes sitting on wood planks in barns,and question how good that could be. I was in a guys shop this summer that was built like a boat house over the water. This guys repaired props for boats, and the whole place was made out of wood. The lathe in that shop was huge compared to mine , maybe so big it could resist twisting like mine.
Whats the fix for this guys? What would you do if you had this happening in your shop? Ever since this hi-way was widened, I having this problem.
Is there a fix, or am I just screwed?
Thanks in advance
Cheers Paul
Thanks in advance
Cheers Paul
