Briggs & Stratton piston to bore clearance - Page 3
Page 3 of 3 FirstFirst 123
Results 41 to 43 of 43
  1. #41
    Dec 2012
    AUSTRALIA
    4,268
    20
    1529
    Just about every small motor now has a nickasil bore,and wear is not an issue....They can be bored out,and a liner substituted ,if there is enough metal in the cylinder.....A friend of mine used to do that to install overbore kits in modern Triumph motorbikes......Seemd silly to me to wreck a nickasil bore to get a few extra cc s.......You can also get nickasil redone,but its not cheap.
  2. #42
    May 2007
    314
    43
    57
    A forged piston will have more clearance than a cast piston, but they will both fit in the same hole. The reason is the clearance is built into the piston.
    Pistons are cam ground on the skirt as they warm up the skirt grows in the direction of the wrist pin. The skirt is also tapered the diameter at the tip of the skirt will be larger than up near the oil ring. The proper way to measure a piston diameter is 90 degrees to the wrist pin at a height equal to the center of the wrist pin.
    Skirt taper, clearance, and cam grind will vary by piston design so it's best not to second guess the manufacturer. A .020" piston will fit a bore .020" over standard. Also make sure you have the correct standard diameter, A sales brochure may say it's a 3" bore but the service manual may say 3.001" bore so make sure you have the proper standard size before sizing the hole.
  3. #43
    Mar 2005
    Kansas
    8,527
    588
    4274
    Quote Originally Posted by gappmast View Post
    Question, how do you measure a piston. I know with a micrometer but where do you measure it.
    Check the piston diameter at the centerline of the pin hole, 90 degrees to the pin.
