Greg Menke
- Feb 22, 2004
- Baltimore, MD, USA
I'm repairing the cross-slide dovetail on my lathe, the last couple inches on the back side were snapped off some time ago.
Back when the saddle got busted it was repaired by 4 long capscrews pulling the rear wing onto the bridge. Once I get the new dovetail pieces fit & screwed down along with a couple other keys elsewhere, then I'd like to braze the entire repair- including the old joint.
So my question is since the repair is stable and the two halves seem to fit very well as is, should I take it apart to prep the surfaces or will it be enough to vee out the joints and rely on flux to get the filler down into the crack?
I think I'll have plenty of heat for the job, I'm borrowing the burner from my brother's turkey cooker to help with the preheat and I'll have an oxy/acetylene rig.
Regards,
Gregm
Regards,
Gregm
