Fountain I had the same problem with my 5914.
You don't want to go all out for these reasons.
- The locking collar is aluminum and can only take so much torque (I didn't damage mine but I do urge caution).
- The spindle lock, or at least my method is to engage the back gear with the direct drive pin engaged. You don't want to trash the geartrain over this.
I used this combination for success
- Penetrating Kroil or PB Blaster..can't recall which right now.
- Put moderate torque on the collar with the spanner to put some pressure on the chuck.
- Use a deadblow mallet or 16oz ball pein hammer + block of wood. Rotate the chuck and strike medium blows to the chuck back flange. Keep rotating and striking.
- When you get tired, douse again with penetrant and go away. Come back later for another workout session
The impact action plus static load should eventually loosen the chuck and you shouldn't damage anything. The tapered roller bearings in the head are reasonably tough. Real metal parts made to tight tolerances can barely resist oscillating or impact forces in real life, let alone a stinky layer of gum or corrosion by itself. You will eventually prevail.
-Matt
