Dip Seal –Crock Pot, need more heat
Results 1 to 13 of 13
    May 2004
    Nebraska
    413
    14
    Post
    I bought a small crock pot to melt Dip Seal for coating resharpened tools however I’m not getting quite enough heat out of it. This crock pot is either on or off there is no high or low setting. Anyone know how I could get a little more heat out of it?
    Feb 2006
    Oakland, California, USA
    1,782
    17
    14
    Post
    Open it up and shorten the heating element.
    I'd assume that it's a coiled wire which can be easily cut and reattached to the feed.
    Don't go too crazy -- I'd suggest you sneak up on it by snipping 1" at a time until it just melts your Dip Seal.
    a
    Jul 2004
    New Mexico
    537
    10
    24
    Post
    I use an old electric popcorn popper. Works great. Gets a lot hotter than a crock pot.
    Apr 2002
    Syracuse, NY USA
    9,829
    19
    624
    Post
    I Have seen frybabies used, but those get real hot so be carefull
    Dec 2005
    BC Canada
    161
    Post
    I bought an old crock / fryer at the second hand store for 20 bucks..... has a thermostat controll up to 450F..... way better than the old simple crock pot I used to use...
    mc2w
    tim
    Jul 2005
    North(very) West(very) Ohio...near exit 13 on OH turnpike
    3,680
    186
    Post
    A garage sale deep fryer is the solution.
    It is nice to be able to change the temp to alter the thickness of the dip coating you get too, hot for thin, colder for thick.
    Bill
    Oct 2005
    Putnam CT USA
    570
    163
    23
    Post
    If the pot has an insert like a slow cooker, put a thin piece of wood under the insert thus not allowing it to overheat.
    Another way is to connect it in series from a light bulb....juice in the bulb...out the bulb to in the heater...out to common. Depending on the amount of wattage the bulb uses will affect the amperage (heat) in the Dip Seal.
    Jan 2004
    Williams Lake, BC, Canada
    2,892
    10
    Post
    Hook it up to 220.
    Jan 2003
    Jacksonville, Florida, USA
    2,324
    10
    Post
    Isn't that dipseal stuff flamable at a temp slightly above the melt? Be careful of your temps.
    David from jax
    Jul 2005
    3,680
    186
    Post
    I know if you run it wide open in a deep fryer, then dump it into a cardboard box outside it can ignite the box, just as I dumped it I remembered that Bradbury book "farenheight 451"....nobody got hurt but it made quite a blaze once it got going.
    Bill
  11. #11
    Dec 2003
    North Freedom, WI, USA
    865
    8
    Post
    Some of the crock pot/slow cookers only have a low/medium/high setting on the thermostat. I recently called the company to ask what temperatures they correspond to. 200/250/300 degrees F was the answer. This isn't hot enough for hot dip.
    Four years ago I purchased a Presto (~4 qt.). The thermostat goes up to 400F. I use it without the porcelain liner. If it is half full, it heats up in a few hours. If it's nearly full, it takes several hours. I usually have a batch of stuff to dip every couple weeks and I just let it heat up all day on dip day.
    I purchased some mineral wool from McMaster and wrapped the OD of the crock pot, keep the bottom open. This helps reduce heat loss and reduces heating time. I believe that, given a combination of a full pot of dip, no blanket, and a cold shop, the crock pot probably doesn't have enough wattage to ever get up to temperature.
  12. #12
    Sep 2019
    Iowa
    6
    I realize this is an old thread but I had the same issue. The Panasonic Panasonic NF-851E Fondue Tempura pot is working great for me. It can get much hotter than the hot dip temp if needed but the temperature control on the front makes it easy to get the temperature you want. It only cost me about $6 as well.
  13. #13
    Jan 2014
    Temecula, Ca
    3,384
    1414
    4410
    i just use a regular crock pot, however mine goes up to 11.
  14. Likes digger doug liked this post
