Enco Kurt vise copies
Without a doubt, go for the used Kurt! I've used both the 'clones' and real Kurts in 30 years of making chips; some of the clones are ok, some REALLY s**k! It's a crapshoot. I once worked in a shop that had two Enco clones,one was fairly decent, the other was a total POS. Don't scrimp on your tools, if you want to make good parts.
RAS
i have four vises, all kurt style.....
1 is chinese
and pretty well made and accurate . another is
a Yuasa , (japan) and despite having seen tons
of use is still dead on accurate(cost about the
same as a kurt),a very well made tool.
....then there's the India-made crap. no bargain
at any price(84.00 from enco). i bought these
two vises thinking they'd be decent like the
chinese one i bought first.... the jaws aren't
flat on one...as in just eyeballing it . running
an indicator along the fixed jaw reveals a .023
dip (how do they grind that dip into the jaw?)
the other vise's thrust bearing failed after
about ten parts, sending a chunk of aluminum
flying into the door of my haas.
some taiwan vises i've used were well made,
but cost nearly as much as a kurt($300)
PTS had a closeout on some japanese kurt-type
6 inchers for around $225 last time i looked.
I've got the 6" Enco, no complaints, but then again, I've never tried a Kurt so maybe my ignorance is bliss.
The back face is pretty straight, maybe 0.0015" bow or less. At one point I reground the bottom surfaces.
It came with the angle mount, but I never used it, so I set it aside and bolted the vise directly to the table.
The biggest problem I have had is with rust forming between the vise and the table, lifting the vise up and screwing up the level. I use the no-rust coolants but still get a little rust anyway. About every two months I have to take the vice off the table and clean underneath.
I have used both the real Kurt and the Chinese
copies. If you can find a deal on a used real Kurt, go for it. If you go import, as others have said, go over it with an indicator and see what you have before you start using it. One vise I have is within .0005 over the bed, on the swivel.
The back jaw is within .0002". The other is out
about .0015 on the bed and a little under .001 on
the back jaw. If you know what you have, you can compensate for it on the "fussy" jobs, but it's still nice to have the best tools if you can afford them.
As for rust under the vise, there is an old wood worker's trick that may help. Put a heat lamp on the bottom surface until it's hot, and rub
some "Butcher's Wax" or similar hard paste wax into the iron. I've never tried it with coolant, but my table saw doesn't rust anymore, and I don't have to use oils on it that would get on the wood. It seems to seal up the pores in the iron and keep moisture from getting into the grain. I don't think it would help much on steel, but on cast iron it works well.-JM
I opted for a used Kurt and am not sorry. I bought it right with a swivel base. I did replace the jaws. A surface grinder will bring a Kurt back to spec real quick (although I did not have to). I would rather spend a little $$$ on a used made in America Kurt than an Asian anything. In my opinion, you could get you money out the Kurt, specially if is is clean and true) and would be lucky to get fifty cents on the dollar for the Asian, regardless of the condition.
Grits
I've got a couple of Kurt vises, and never had to touch them. I've also got a few cheaper copies of various expensive vises, and spent many hours reworking parts to make them usable. One way or another, you pay :D
I have the Enco 6" with swivel base. This vise has worked very good, for anything that, I have made on my mill.
I will admit that I have never used a Kurt.
My .02.
They have one at work. It's not level side to side by .002". so far I've been shimming it but like lklb says it needs to be ground (don't have a grinder there). A used Kurt would be better but a Chicom with alittle work will get you by.
Jon
kurt clones are fine for the home shop.
I broke a kurt clone at work, the nut broke, I had to get it tight to line bore king pin holes in a semi truck front end.
A kurt vice is much tougher.
come to think of it, I have bad luck with bench vices, one day I broke 2.
A few recent posts have praised Gerardi vises, which are about $150 more than a low-end Kurt. Has anyone compared the two? I need a vise for my newly-acquired Tree.
I purchased an Enco 4" Kurt clone vise about 4 years ago. It was not perfect, but for the type of service I used it for (HSM model engines) on my mill/drill it was ok. Later, I flycut the base and that improved it. I used it until about a year ago when I replaced it with another Enco vise. This one is a 5" model that is marked as an "Elephant" brand vise. It is a much better quality, I presume, Chinese made vise. It is quite accurate and I have had no problem with this vise. I didn't even bother to purchase the swivel base since I rarely ever used the one on the 4" model. For homeshop, occassional use, this vise is more than adequate especially for the $75 (and free shipping) that it cost. When I buy that Bridgeport I have always wanted, I will get a real Kurt.
enco vise
the enco vise also gibraltar are bad we used them for 6 months they all blew out still trying to get a refund don"t buy them.
