End mills- 2 flute or 4 flute?
Likes Likes:  0
Results 1 to 18 of 18
    Aug 2003
    Birmingham, AL USA
    62
    I'm ordering some tooling for my BP mill and need some info on end mills. As a newcomer to machining I don't know which to buy for general machining usage. Could someone explain briefly the differences in 2 flute and 4 flute designs and when you generally use each? I just need some general guidelines.
    I have tried to access the US military website on machining info several times today and it seems to be down.
    I want to get my order placed ASAP before SWMBO rescinds her authorization for me to buy *some* tooling.
    Thanks, Mike
    Jul 2003
    elmhurst, illinois, usa
    595
    best bet is to have a selection of both. But a real quick rule of thumb is 4 flute for steel and 2 flute for aluminum or soft metals or any cut where you need the chips to clear out fast and easy.
    disclaimer: That a real loose quick rule.
    May 2003
    Iowa
    10,492
    3616
    4261
    The 2 flute have a larger gullet so more chip clearance. For smaller mills (below 1/2 inch) a 2 flute is a better roughing mill. For finish work or in hard materials, you need more cutting edges so use a 4 flute.
    If you're going to be working in aluminum, you'll want to get some "high Helix" end mills. The same principle applies between 2 and 4 flute.
    JR
    Jan 2003
    Ireland
    138
    Hi Alrednek.
    2 flues are slot drills which you can use to drill into a metal and then cut, as opposed to end mills which have 3 or 4 flutes and made for side machining only.
    There are always exceptions though eg. 3 fluted slotdrills etc.
    Aug 2003
    Birmingham, AL USA
    62
    Thanks guys. I appreciate the help. I think I'd like to have some of each type. I'm looking at a 20 pc. set from Enco (imported) that are tin coated HSS. The set has 10 each- 2 flute and 4 flute, from 3/16 to 3/4 by 16ths. I understand that the imported stuff is questionable in quality but would this be OK as a starting set? It's less than $40. on sale so it won't break the bank. Oh yeah, free shipping too since I'm buying other items that will go over $50.
    Thanks again, Mike
    Oct 2003
    S.E. Pa., USA
    529
    25
    You might want to invest in some roughing mills as well. These are often referred to as cob mills. It will mean an extra tool change,but it will save your cutting edges on your regular endmills when milling through the scale on hot rolled steel or heat affected zone on flame cut stock. I would also get some 3 flute end mills for working aluminum. Sometimes 2 flutes just want to chatter and 4 flutes do not have the chip clearance needed.
    Dec 2002
    Safford, Az., USA
    1,311
    I have had great luck buying endmills and cutters from ebay. I only buy American or good quality. The enco, made in china cutters leave a lot to be desired. I have dulled some of them very quickly and now give up on them. I have bought top quality endmill from ebay as cheap as the enco mills.
    Michael
    Sep 2004
    292
    The cheapo enco sets are okay to have around for occasional use when you need a special size, but they won't last long. I've got a cheapo set for that purpose but I use US made 1/2" or 3/4" endmills for any serious milling. I've also got some roughing endmills that I use for the first pass if I need to make a big cut, they work great.
    I generally use only 2 flute endmills for both steel and aluminum since they're more versatile. If I need to take heavy cuts I'll switch to a roughing endmill and go back to the 2 flute spinning fast for a light finishing cut.
    Good luck-
    Paul T.
    Oct 2002
    23
    Best to have a variety, but I agree - 2 fluters are more versatile. They plunge better than 3 or 4 fluters and when you want a smooth cut on the side just increase the speed.
    May 2003
    Yorkshire UK
    309
    11
    You will find that if you use a four flute "end mill" for cutting a slot, it will try and walk sideways as the cut progresses.
    You need to use a two flute "slot drill" to minimise this.
    The reason is that when one tooth is cutting out the material at the end of the slot, the other is in free space at the back and not influencing the direction, however with a four flute cutter you would always have at least two teeth trying to cut and more sideways deflection is imparted to the cutter. This is why the two flute ones are called slot drills, the also have one end cutting edge longer than the other which passes over the centre line and allows it to plunge cut into the work for blind ended slots. A four flute can not do this as they normally have a centre in the cutting end, and would require some sort of pilot hole.
    Try it out on a bit of scrap with the same size cutters in both two and four flute versions, you will see what I mean.
    Phil
  11. #11
    Oct 2003
    Greeneville Tn. US
    86
    I agree on the cheap combos of 2 and 4. Ive been using a Grizzley 49.00 set for over 2 yrs now for simple tasks but when you get serious go for Carbide. Its not a thing to me but I have to plug Kodiac for performance and pricing on end mills. They are US made and priced very reasonable. MHO...Jack
  12. #12
    Mar 2001
    New Haven, CT
    3,488
    44
    670
    From what I've heard from friends the cheapo sets are just that, cheap. but it may make sense for you to buy the set, just to learn if the price is right. My first time using a mill I went through quite a few endmills untill I got it right. Stupid beginners mistakes like milling the wrong direction, but I am sure glad it was only $3 cutters and not nice Niagras. But once you get good you tend to want to get decent endmills. American, Polish, Israeli, and recent Japaneese so far are all good, the Chineese ones don't quite hold up.
    I don't know if it is available to you, but you may be best off finding a good used source of endmills. Endmills, can sure break a meager hobbiest wallet, at a few $$'s each however at the same time, if you keep your eyes and ears open you may come across large quantities of them in nice condition either dirt cheap, or free from friends and local industries. I myself went through a period of time where I got about 300 of them both from 2 friends cleaning out their shops, and the rest from a company who takes pictures of them at work in my shop. Not bad? When these things are sold, they tend to go in large lots, I even see guys on ebay from time to time advertising 25lbs of endmills, I don't know the quality of them. Additionally we have a local used toolstore in Worcester, that tends to have endmills ranging from $1-5 each depending on if they are carbide, and size. Since my machine can take 1" endmills and most of the guys with R8 can't I once got about 5 carbide almost brand new Niagra endmills for example for $3each. Also from what I hear these types of things go pretty cheap at auction too. So keep your eyes and ears open. When a company is quoting a production run, the cost of endmills is relitively cheap and all factors into production, when you or I go to use them the $8 here, $50 there can be a killer.
    Other suggestion may be to stay away from carbide till you know what you are doing, as it chips easily. By the way, whom ever suggested getting some roughers is right on the money I never used them untill recently when I got a few for free and now I just want more. They are great for all sorts of heavy hogging, and really removing material fast. Only now do I have a band saw, but prior to that I was doing cutoff operations with roughers and they just chewed right through.
    Adam
  13. #13
    Aug 2003
    New Hampshire
    50
    The $49 Grizzly set will definitely get you down the road. I'll take a sharp cheapie endmill over a dull quality endmill any day of the week. The import endmills are fine for anything but the most demanding jobs anyway. Do your wallet a flavor and buy what you can afford, not just what the status quo tells you.
  14. #14
    Sep 2001
    Midland, Michigan
    668
    I have the same 20 pc. set in a MSC sales flyer for just under $40.00. I don't find this set on-line at ENCO where I would also benefit from FREE shipping on a $50.00+ order. Where did you find the set, help. TIA. Steve
    [This message has been edited by Steve Stube (edited 03-11-2004).]
  15. #15
    Aug 2003
    Birmingham, AL USA
    62
    Steve, I found the set listed in a flyer from ENCO. I've included a link below that you can use.
    I've decided to order the set just to have all the different sizes and one of each type...also if I screw one up so what? no big deal.
    Thanks all, for the great input...it is much appreciated.
    Here's a link for the end mill set:
    http://www.use-enco.com/CGI/INSRIT?PMAKA=CR320-0000
    Item # CR320-0000 Page 85 of Catalog
    Mike
  16. #16
    Aug 2003
    Simi Valley, CA
    763
    I'm another advocate of buying used. I didn't get quite the deal Les got by buying half a truckload of them at auction for $40.00, but I found a nice old man who was selling off his tools as his Parkinsons would no longer allow him to use them. I got an assortment of nearly all the end mills you would probably ever need for $100.00. They weren't free, but it was quite a bargain considering what I got. They're mostly all good US made stuff in everything from .050 through 2.00 (with .750 shaft). Probably over 100 pieces including all sorts of formed tools like radius cutters, ball end mills and keyway cutters. Most all of them are in sharp, ready to go condition, and the few that need sharpening can be sharpened cheaply or tossed.
    At least in So. Cal there's an amazing amount of old guys who had home shops and are selling them off at fair prices to save their families from having to do it later. I've outfitted most of my shop from guys like this. Not only have I got some good deals from these smart old guys, but I've certainly learned a few things from them along the way. There's so few people who have any interest in what they did, and so many of their friends are dead, that they're happy to talk shop a bit with a younger guy (I'm 41), make you a deal on some of their most prized possesions and pass the torch. It's great to see the sparkle in their eye when theydescribe what they used to use a certain machine or fixture for. It's also a little sad when they aknowledge that they just can't do it anymore, generally for health reasons (why else would you give up your machines?). I find myself better for the experience. Sometimes when I meet a guy like I've described who wants more than what I think the stuff is worth, or I can afford. When that happens I try to realize the emotional (and perhaps financial) investment they've made in their tools and I can't bring myself to grind on price. So I enjoy the time with them, try and learn a bit and leave them with their tools and dignity.
    That reminds me, I have to call the guy I got the end mills from (and a surface grinder, and a bunch of other cool stuff) this weekend to arrange to help him transfer some old reel to reel tapes of his son to CD Rom for him. Sometimes you even make a friend with these deals. From what I've found, these older fellas don't do ebay or the internet for the most part. You find them in your local paper's classified section, the Pennysaver, Recycler, etc. Most of the guys I've found have been mid 70s to mid 80s and are all in failing health. What I need to find is a 60 something master machinist who's selling his shop and wants to travel, but would like visitation rights and was in good enough health to come over and visit his stuff and mentor me.. Heck, I've got almost all the stuff needed now anyway, so I just need the old, experienced mentor who no longer has access to a shop of his own..
    John
    [This message has been edited by Excitable Boy (edited 03-11-2004).]
  17. #17
    Mar 2018
    UGANDA
    20
    I wanted to add to this old thread since technology and costs have changed so much and newcomers to machining ďMayĒ find it helpful. This is long though hoping you find it useful. As previously stated eBay is still an excellent source as well as All Industrial who has a website and on eBay, Shars, Yg-1 end mills, indexable for alternatives and Kyocera insert cutters are not only cost affordable but probably some of the best if not probably professional inserts Iíve used in my machine shop. Since going into business for myself itís forces the hand in finding effective means in quality and performance at a cost affordable means which can be difficult and for myself was an expensive learning experience. Much like paying for an education. It is like anything paying for a quality vice. Where I have a Kurt on one machine and a upper tier Chinese on another and I will say there is a difference but both do serve their purposes. For Aluminum I find the aluminum high helix Yg-1 work well. For squaring parts and prepping work I will often use indexable face mills or appropriate sized cutters with apmt11 sized cutters. I believe stamped G2/80 Kyocera which are $9.90 a pack of 10 or $8/pk for 3 or more. These have saved me thousands of dollars in endmills and time in labor machining parts where I am left only having to complete pockets, slots, and through holes after initial machining. For steel I typically work with 1045, 8620, 4140, and 17-4ph for the majority while there are others those are the common materials and typically very hard on tooling. I have found the best results are with indexable cutters including R390 sandvik and you will find on eBay you can get 10 packs of Chinese clone inserts for $7/ea. I often wonder if they are truly clones or original manufacture because they work absolutely fantastic. I use single, double, triple flute hot to 3/4 and face mills. For pockets, slots, through holes, etc.., I resort to 5-7 flute end mills. I havenít had any luck with anything less than a 5 flute. Perhaps others reading have it may be a result of equipment, etc... I find that multi flute cutters will peel through the material very well and Iíve even had cutters that have dulled and the worst case was a rounded versus square shoulder cut which for many parts Iíve made have been fine so I keep them and run them until they are dead. I typically find the 5-7 flute 1/2Ē Kyocera coated and like sgs end mills for around $25-$30 each of I shop careful on eBay. If not you will pay $50-$60 each. Many times I end up bidding on auctions and getting 2 for $55 and if I only need one I will sell the other for $49.99 and keep the one I need dropping my tooling cost significantly for that particular end mill. If you have the time to be savvy online and take advantage of larger auctions keep in mind you can resale some of the items to offset your expenses significantly however this may require you regularly shop to keep your inventory up to date. As far as the indexable holders Iíve typically paid $5 to $40 you have to shop carefully and have found some beautiful tooling. Accusize has a wonderful multiple 6 insert 3/4 helica cutter for $75 on Amazon (normally $110) and you can cut pockets, finish edges, square, surface, etc...my face mills come from a seller called CNGX and another is something like 6-48086 on eBay and those used to be much cheaper but now for example my 100mm (4Ē) 6 flute cost $75 and will give a mirror finish on aluminum. Even my 2Ē cutters from them do. I have purchased at least a dozen between both those sellers and they are cost affordable and excellent solutions. One thing I always consider is any cutter I use I want even the first pass to look like the last so I have high expectations even for the cheapest of endmills, tooling, etc.., of I make a .25 deep pocket .5 wide and donut in one pass I want it done and finished without screwing around with a .010 pass to finish. I know itís unconventional but when youíre machining as a two man operation profitability is the utmost consideration and time is everything while keeping quality and appearance above standard. I except even my manual machined parts to look like they were cncíd. This was the approach I took in finding the tooling we use, finding the most affordable, longest lasting tooling we could bring in house without breaking the bank every week repacking them. Today I look back and realize how little we spend in replacement tooling and the fact we get to put that money toward new toys for the shop means we can progress toward new projects and discover new techniques in machining. One process that used to take 2 hours contouring a part horizontally We one day turned that part vertically, clamped it in with a custom fixture and used a apkt11 6 flute face mill to cut down 3.5Ē of the part .34 deep contouring it in 4 plunges taking 3 minutes and leaving a mirror finish instead of all those wonderful marks we often see from end mills. Itís finding the right tool for the job, being innovative, outside the box that saves us money, improves quality, and proves we donít always need the most expensive tooling to do the task properly.
  18. #18
    Dec 2010
    Mifflintown, PA 17059
    1,607
    17
    157
    Center cutting 3,4 or more endmills will plunge cut. Not as well as 2 that have more chip clearance but they will plunge cut and I use them all the time. I would stay away from to cheap sets. I have purchased them and probably still have them since I don't use them. Not sure why, they look really good, seem sharp and do cut BUT the surface finish on the ones I got look like the cutting edges have nicks in them. I get a series of lines though the cutter looks as good as a top end Niagara! Your would be better off watching ebay, I do and get some top brands New in the box for lot less money than from MSC or others.
