D
D. Thomas
Guest
Is it a regular pneumatic tire filled with foam, or is it just a larger diameter version of a cushion tire ? or something else altogether ?
Reason I ask is I assumed it was a pneumatic tire filled with foam, but I keep seeing used lift trucks with those type of tires where there are major chunks broken off the tire edges and often cracks in the sidewalls, just like worn cushion tires.
But if it's really just a high profile cushion, how is it they can run on dirt without getting stuck ? Which brings up another question...will they run on dirt just as well as a standard pneumatic, or do they tend to get stuck more often ?
