Futaba DRO
AviatorDave
Feb 5, 2008
The used bridgeport I bought a few weeks ago has a Futaba Pulscale CJ2004 DRO on it. Anyone have anything that resembles a manual for it?
It will turn on, and increment when I move the table, but the values are way off. When in inch mode, it goes out to 6 decimal places, but one full turn of the handle only increases the value .040".
I've tried it in absolute mode, incremental mode, everything. There are some buttons that are unreadable, however. I tried to see if any of them made a difference, but none do.
Powering it off, unplugging, and R&R the battery doesn't fix it either.
I have no manual but it sounds like your problem may be that the encoders are not set correctly and as a result the travel is not reading out correctly.
Today I had this problem on my newly installed DRO (Acu-Rite). I turned the handles of the Bridgeport and the readout said the table moved .650 inches (5/8 inch approx) but I had clearly moved the table several inches.
A call to Acu-Rite solved the problem. Turns out I had set the encoder at .5 UM and it should have been set to 5.0 um. (Don't even ask me what the heck um means) After the correct setting was entered, one inch on the meter was inch on the table movement.
This may not help you at all, but on my DRO the encoder set up is listed under 'Installation Install' and then under 'Encoder Settings'.
So, try to check what your encoders are set at. Google Futaba and see if you can get a lead on where you can call for customer service if you cannot find where/how to check the settings..........pg
Yeah, I've been trying to JFGI for a few weeks now. That's why I was looking for a manual or somebody that has one here - Futaba sold this line long ago to Sumtak in Japan, who in turn sold it to Heidenhain, who discontinued the line altogether. There's some company in China that still appears to carry them, but the entire website is in Chinese. I've called Sumtak USA and Heidenhain USA and they either refer me back to the other one, or tell me that they don't have any archive of information on them anymore.
I did find one other person with the same problem in a usenet newsgroup, but his post was from over 3 years ago so I doubt he'll ever even see my post asking if he ever figured it out or not.
The guy I bought the machine from is sending me another Futaba DRO box, which should use the same scales, but even if it works, I still won't have a manual. It is a slightly newer model, a CJX201 he told me. Hopefully it will just work as I don't want to fork out another $1k for another DRO system.
OK. Sorry I could not be of more help. I am pretty sure there is a good chance the problem is with the scale adjustment. Maybe the replacement unit will let you find access to the feature.........pg
Well crap. I got the replacement DRO box. It's a newer model, but with basic functions, not hole patterns and the like, which is fine with me.
But I hooked it up to the scales and it does the exact same thing - .2" of table travel = .040" of screen increment. It's counting 5x too slow. I took the cover off of one of the scale read heads only to find 5 pot screws.
I have no idea where to go from here besides shelling out a chunk of change for a new DRO system.
Damn.
Damn.
Can you read the button functions better on the newer one? I recall you said there are some buttons that are 'unreadable' on the older head.
If so, what you want to do is get access to the 'Set up' function and then find the encoder settings. See what it is set at. You will want to set them at a 'courser setting'........pg
That's the problem - no manual, and there's no button labeled 'setup'. But no matter, I figured it out what caused the problem on the old box, and got the new one working.
I took the newer box apart and found 4 banks of 8-pole dip switches. X1 and Y1 were all off. X2 and Y2 had 2, 4, 6, and 7 all on. So I started randomly changing dip switches. I first got it to go to .400" with .2" travel, so knew I was on the right trail. After a few more tries, I got it to work perfect.
This let me understand why the original box didn't work - on the back it said "Replace battery at least once every 6 months." There was a battery compartment on the side with 2 AA batteries. I took out the old crusty corroded ones and put in 2 new ones when I was originally troubleshooting it. So I'm sure that those batteries were deader than door nails, and when they unplugged it to ship it, it lost the setup parameters.
But I'm good to go. I just wish now that the old box's button pad wasn't so screwed up as it had some nice features, like a connector for a zero-set probe, bolt circle patterns, etc. No matter, I can do all that on a PC anyways.
But thanks for your help.
Glad to hear you have it set. It sounded like the encoders needed to be set correctly, based on my recent experience with mine.
Perhaps with the newer box you will, in time, discover what each button's purpose is. Somewhere in there is the button to allow you to get to the parameter settings.......pg
PS: Maybe you can post a picture of the face of your unit. Seeing the buttons may give me some idea of which does what. I cannot guarantee that however.
I found this thread while trying to reconfigure a CJX (CJX101) for a scale. (Got the pair 6 years ago at an auction, NOS, didn't realize it was so old already when I bought it!) There are several other threads asking how to match scale resolution on CJ and CJX dro's.
I realized after poking around inside my unit that the thing I thought was a brochure was actually its manual. I've uploaded it in case anyone needs it in the future. You mess with the first three dips on the second bank (Y2 or X2) to change scale resolution. I have to assume it's the same for CJ's as they're older?)
Pulscale CJX "manual"
